How to send symboles
I don't really understand the documentationm can you help me send a symbole using a VBS Macro File
Re: How to send symboles
VBS samples are part of the online documentation. But we could send you a sample package for better understanding.
Please send a E-Mail to support[at]peak-system.com
The main important Information is to understand that a Signal could be "bind" to a VBS Variable, and so you could set and get the Signal value very easy.
In the Symbol File "Power" is a signal defined called "Voltage" and one called "Current"
In VBS, you could after this code access directly to the Values of the Signal
Reading
or Writing
then the CAN-ID (Symbol) that stores the Signal Voltage will be automatically send to the CAN-Bus.
This is a very simple sample, but explain in basic how it works.
' Name of the used Symbol file we want to use (we could have many in one project)
Set symbol = SymbolsManager("Power")
' We use the predefined CAN Signals from the Symbol File we select
Set voltage = Signals("Voltage")
Set current = Signals("Current")
Reading
Power = Voltage.Value * Current.Value
Voltage.Value = 220
Thank you, I sent an email
