Dear Support,
according to documentation the Peak Converter is able to convert from trc to mdf4.
I need to do this via command line but found nothing in the documentation how to specify the dbc file for transformation to mdf4.
As far as I understood dbc file is necessary to be able to mdf4.
Can you please share how to convert trc via command line to mdf4?
Peak-Converter: Can you convert a tracefile (.trc) to MDF4 (.mf4)?
Re: Peak-Converter trc to mdf4
the PEAK-Converter works only with raw CAN data. It doesn't support any DBC or Symbol file for data interpretation, for any of the supported formats (TRC, ASC, BTR, BTRC, MF4).
