PCAN-Explorer 5 Unable to Run Sample VBS Macros
Posted: Thu 18. Apr 2024, 01:06
by dtran
I am running into an issue in PCAN-Explorer 5.3.4 that is very similar to the issue reported on this thread: viewtopic.php?t=2984. I cannot update to PCAN-Explorer 5.4 since I need the instrument panel option (got a message stating instrument panel requires 5.3).
When I run the sample script called "NewClientSend" my PCAN-Explorer would abruptly exit. This test is to rule out my script.
In my VBS script, I have determined that the following code will cause the script to terminate:
   Dim client
   MsgBox "Here!"
   Set client = CreateObject("PCAN3.PCANClient")
   MsgBox "Won't reach here!"
Warning Message:
PCAN Warning .png (9.44 KiB) Viewed 2220 times
Any suggestions on how I can fix this without upgrading my PCAN-Explorer?
Re: PCAN-Explorer 5 Unable to Run Sample VBS Macros
Posted: Thu 18. Apr 2024, 14:12
please send an email to our support email address with your license ID of your PCAN-Explorer 5 and your project files, to be able to check the issue.
best regards
Posted: Fri 19. Apr 2024, 18:01
by dtran
Thank you, Michael. I have sent you the email with the information requested.
Posted: Mon 22. Apr 2024, 08:50
by M.Heidemann
Support provided via email.
- closed -
