Regarding LIN Communication Issues in Master Subscription Mode with PLINViewer and controller
Posted: Thu 25. Apr 2024, 12:25
I'm encountering challenges while attempting to request data from an NXP slave device using PLINViewer as the master. Here's a breakdown of the issue:
Problem Description:
When configuring PLINViewer as the master and attempting to request data from the slave device, I'm facing difficulties. I've set up a new frame in subscription mode, sent the frame, and simultaneously monitored the LIN line using an oscilloscope. However, I'm not receiving the correct ID during transmission. The oscilloscope is capturing a same 6-digit number as the ID[0x3f635547] for different ID transmission, and I'm not receiving a reply from the slave.
Observations:
Interestingly, when sending data in publisher mode yields correct ID and data from the slave device in the oscilloscope.
1. Is it possible to request data from a slave device using master mode in PLINViewer?
2. if yes, why i'm not able to capture the ID value on the oscilloscope and it's shows 6 digit number?
Attached the image for reference. Any insights or guidance on troubleshooting these issues would be greatly appreciated.
Thank you,
Observations:
Thank you,
