UDS testDiagnosticSessionControl
vmedvedev
Post by vmedvedev » Sun 28. Apr 2024, 20:53
I am learning UDS and exploring UDS API. I am trying to run example testDiagnosticSessionControl from 06_client_all_request solution here is my code
 cantp_handle client_handle;
 uds_status status;
 UInt32 dw_buffer;
 uds_msgconfig config = new uds_msgconfig();
// Set the PCAN-Channel to use
 client_handle = cantp_handle.PCANTP_HANDLE_USBBUS1; // TODO: modify the value according to your available PCAN devices.
 status = UDSApi.Initialize_2013(client_handle, cantp_baudrate.PCANTP_BAUDRATE_250K);
 Console.WriteLine("Initialize UDS: {0}", (int)status);
 //cantp_handle channel = cantp_handle.PCANTP_HANDLE_USBBUS1;
 cantp_status result;
 cantp_mapping request_mapping = new cantp_mapping();
 cantp_mapping response_mapping;
 request_mapping.can_id = 0x781;
 request_mapping.can_id_flow_ctrl = 0x7F1;
 request_mapping.netaddrinfo.source_addr = 0x11;
 request_mapping.netaddrinfo.target_addr = 0x22;
 request_mapping.netaddrinfo.extension_addr = 0x0;
 request_mapping.can_msgtype = cantp_can_msgtype.PCANTP_CAN_MSGTYPE_STANDARD;
 request_mapping.netaddrinfo.format = cantp_isotp_format.PCANTP_ISOTP_FORMAT_NORMAL;
 request_mapping.netaddrinfo.msgtype = cantp_isotp_msgtype.PCANTP_ISOTP_MSGTYPE_DIAGNOSTIC;
 request_mapping.netaddrinfo.target_type = cantp_isotp_addressing.PCANTP_ISOTP_ADDRESSING_PHYSICAL;
 // Defines a second mapping to allow communication from Destination 0x22 to Source 0x11.
 response_mapping = request_mapping;
 response_mapping.can_id = request_mapping.can_id_flow_ctrl;
 response_mapping.can_id_flow_ctrl = request_mapping.can_id;
 response_mapping.netaddrinfo.source_addr = request_mapping.netaddrinfo.target_addr;
 response_mapping.netaddrinfo.target_addr = request_mapping.netaddrinfo.source_addr;
 // Add request mapping
 result = CanTpApi.AddMapping_2016(client_handle, ref request_mapping);
 if (!CanTpApi.StatusIsOk_2016(result, cantp_status.PCANTP_STATUS_OK))
     Console.WriteLine("Failed to add request mapping.");
 result = CanTpApi.AddMapping_2016(client_handle, ref response_mapping);
     Console.WriteLine("Failed to add response mapping.");
 // Define TimeOuts
 dw_buffer = CanTpApi.PCANTP_ISO_TIMEOUTS_15765_4;
 status = UDSApi.SetValue_2013(client_handle, uds_parameter.PUDS_PARAMETER_ISO_TIMEOUTS, ref dw_buffer, sizeof(UInt32));
 Console.WriteLine("Set ISO 15765-4 timeouts values: {0}", (int)status);
 waitGetch();
 // Define Network Address Information used for all the tests
 //config.can_id = (UInt32)0xFFFFFFFF;
 config.can_id = (UInt16)0x781;
 config.can_msgtype = cantp_can_msgtype.PCANTP_CAN_MSGTYPE_STANDARD;
 config.nai.protocol = uds_msgprotocol.PUDS_MSGPROTOCOL_ISO_15765_2_11B_NORMAL;
 config.nai.target_type = cantp_isotp_addressing.PCANTP_ISOTP_ADDRESSING_PHYSICAL;
 config.type = uds_msgtype.PUDS_MSGTYPE_USDT;//usdt
 //config.nai.source_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
 //config.nai.target_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1;
 config.nai.source_addr = (UInt16)0x11;
 config.nai.target_addr = (UInt16)0x22;
 // The following functions call UDS Services
 testDiagnosticSessionControl(client_handle, config);
Mapping does not produces error. Application log produces NO UDS Response error
UDS request from 0x0011 (to 0x0022, with extension address 0x00) - result: 0 - OK !
-> Length: 2, Data= 10 02
/!\ ERROR: NO UDS RESPONSE !!
Free request message: 0
Free response message: 0
Free confirmation message: 0
Diagnostic Session Information: 0, 0x0022 => 1 = [0032; 01F4]
Assert that Auto TesterPresent Frame is sent...
Should transmit an Auto TesterPresent Frame
When looking at GRID-View trace
;$FILEVERSION=1.1
;$STARTTIME=45410.563111713
; Start time: 4/28/2024 13:30:52.852.0
; Generated by PCAN-View v5.2.0.926
; Message Number
; | Time Offset (ms)
; | | Type
; | | | ID (hex)
; | | | | Data Length
; | | | | | Data Bytes (hex) ...
1) 1013.9 Warng FFFFFFFF 4 00 00 00 08 BUSHEAVY
2) 37370.1 Rx 0781 8 02 10 01 55 55 55 55 55
3) 37371.7 Rx 07F1 8 02 50 01 00 00 00 00 00
4) 47432.0 Rx 0781 8 02 10 02 55 55 55 55 55
5) 47433.7 Rx 07F1 8 02 50 02 00 00 00 00 00
6) 61511.9 Rx 0781 8 02 10 01 55 55 55 55 55
7) 61513.6 Rx 07F1 8 02 50 01 00 00 00 00 00
I see that message sent 02 10 01 55 55 55 55 55 but should be 02 10 01 00 00 00 00 00. Response message looks correct 02 50 01 00 00 00 00 00
I also including mapping information from ECUBus I am trying to replicate.
Thank you for any help.
!! changed to a readable format by ADMIN - please see Forum Rules !!
Re: UDS testDiagnosticSessionControl
Post by K.Wagner » Tue 30. Apr 2024, 16:08
Note that you are refering to the padding value. This is per default set to the value 0x55 in our API. If you want to use a different, in your case "0", then you have to configure this by using the parameter PUDS_PARAMETER_CAN_PADDING_VALUE. You can find more information about this 3.5.3, uds_parameter, page 49.
According to the version of ISO-TP/UDS you are using, the API(s) may not respond to messages that are using a different value for padding bytes. Please check that you are using the latest versions of all APIs (PCAN-Basic, PCAN-ISO-TP, PCAN-UDS), and that you are using the same padding value for all messages involved.
vmedvedev
Post by vmedvedev » Thu 2. May 2024, 17:32
thank you for your suggestions.
I tested both disabling padding
            dw_buffer = CanTpApi.PCANTP_CAN_DATA_PADDING_NONE;
            status = UDSApi.SetValue_2013(client_handle, uds_parameter.PUDS_PARAMETER_CAN_DATA_PADDING, ref dw_buffer, sizeof(UInt32));
            Console.WriteLine("Set Padding status: {0}", (int)status);
            waitGetch();
and setting padding value to 0
           status = UDSApi.SetValue_2013(client_handle, uds_parameter.PUDS_PARAMETER_CAN_PADDING_VALUE, new byte[] {0x00 }, sizeof(UInt32));
           Console.WriteLine("Set Data Padding to None: {0}", (int)status);
           waitGetch();
The messages in Grid View Trace looks good now but I still have ERROR: NO UDS RESPONSE
Setting a DEFAULT Diagnostic Session:
 UDS_SvcDiagnosticSessionControl_2013: 587202560
-> Length: 2, Data= 10 01
I am using computer with W11 and only VS 2022 and peek environment installed. Here is dll versions I am using for the project
Please, advise what I need to check additionally.
Thank you,
Vladimr
Post by K.Wagner » Fri 3. May 2024, 12:12
Note that you are using a different, non standard, communication context. In our Api you need to extra configure such a behavior. Please check the chapter 4.3.1, "Usage in a Non-Standardized Context" within the PCAN-UDS API documentation.
Moreover, I see some bus errors (BUS_HEAVY/BUS_LIGHT) in your trace. This could cause problems, as this is a hint of physical problems. And finally, I see a mixing of data with padding and without padding (optimized). This makes also a difference in the API for messages to be recognized or not. See "PUDS_PARAMETER_CAN_DATA_PADDING" for more information.
vmedvedev
Post by vmedvedev » Fri 3. May 2024, 23:33
thank you very much for your help. After deleting default mappings and using UDSApi.AddMapping_2013 instead of AddMapping_2016 the timeout error went away. It is working both with padding disabled (mixed mode) and padding enabled with value set to 0.
Post by M.Heidemann » Mon 6. May 2024, 08:48
Thank you for letting us know!
For further questions, make sure you open a new topic.
- Thread closed -
