question for SvcReadDataByIdentifier_2013
Kevin1
Post by Kevin1 » Wed 26. Jun 2024, 12:25
I am using SvcReadDataByIdentifier_2013to request 0x22 service to ECU like 22 01 01.
however I am not sure how can I send 0x21 service to ECU? like 21 01 01?
it looks like SvcReadDataByIdentifier_2013send always 0x22 service only..
F.Vergnaud
Re: question for SvcReadDataByLocalIdentifier_2013
Post by F.Vergnaud » Wed 26. Jun 2024, 12:45
The first data byte you are trying to change is the Service ID. Changing this byte means you want to use another service...
- The standardized UDS service is ReadDataByIdentifier (0x22).
- Service 0x21 is not a standardized UDS service.
- Check ISO 14229-1:2020 for the complete list of standardized UDS services.
To request a custom service, you will have to use function UDS_Write_2013 instead of UDS_SvcReadDataByIdentifier_2013.
You can check sample "07_read_write_uds" to see how to allocate and initialize a uds_msg.
You can still use UDS_WaitForXXX function to retrieve the Tx confirmation and the ECU's response.
Kevin1
Re: question for SvcReadDataByIdentifier_2013
Post by Kevin1 » Thu 27. Jun 2024, 17:29
hello
thanks for your feed back. please see my code below, I can do communication with ECU as functional address mode, but I can get ECU response with WaitForService_2013... do I need to use other function to get ECU response?
import os
import sys
import copy
from time import sleep
from PCAN_UDS_2013 import *
import threading
# Help functions
def OK_KO(test):
    return "OK" if test else "KO"
def STATUS_OK_KO(test):
    return OK_KO(objPCANUds.StatusIsOk_2013(test, PUDS_STATUS_OK, False))
def UDS_STATUS_OK_KO(test):
def ThreadWork():
    # Execute ReadDataByIdentifier on 0x5812 and wait response
    TESTER_ID=0x7DF
    ECU_ID=0x7E8
    # Initialize source mapping
    source_mapping = uds_mapping()
    source_mapping.can_id = TESTER_ID
    source_mapping.can_id_flow_ctrl = ECU_ID
    source_mapping.can_msgtype = PCANTP_CAN_MSGTYPE_STANDARD
    source_mapping.can_tx_dlc = 0
    source_mapping.nai.extension_addr = 0
    source_mapping.nai.target_type = PCANTP_ISOTP_ADDRESSING_FUNCTIONAL
    source_mapping.nai.protocol = PUDS_MSGPROTOCOL_ISO_15765_2_11B_NORMAL
    #source_mapping.nai.source_addr = PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT   #0xF1
    #source_mapping.nai.target_addr = 0x01
    # Initialize response mapping
    response_mapping = uds_mapping()
    response_mapping.can_id = source_mapping.can_id_flow_ctrl
    response_mapping.can_id_flow_ctrl = source_mapping.can_id
    response_mapping.can_msgtype = source_mapping.can_msgtype
    response_mapping.can_tx_dlc = source_mapping.can_tx_dlc
    response_mapping.nai.extension_addr = source_mapping.nai.extension_addr
    response_mapping.nai.target_type = source_mapping.nai.target_type
    response_mapping.nai.protocol = source_mapping.nai.protocol
    #response_mapping.nai.source_addr = source_mapping.nai.target_addr
    #response_mapping.nai.target_addr = source_mapping.nai.source_addr
    # Add mapping: 0xF1 -> 0x12
    status = objPCANUds.AddMapping_2013(client_handle, source_mapping)
    #print("Add source mapping on transmitter: %s" %(UDS_STATUS_OK_KO(status)))
    # Add mapping: 0x12 -> 0xF1
    status = objPCANUds.AddMapping_2013(client_handle, response_mapping)
    #print("Add response mapping on transmitter: %s" %(UDS_STATUS_OK_KO(status)))
        # Initialize a physical configuration
    config_physical = uds_msgconfig()
    config_physical.can_id = 0x7df # required for functional
    config_physical.can_msgtype = source_mapping.can_msgtype
    config_physical.nai.protocol = source_mapping.nai.protocol
    config_physical.nai.target_type = source_mapping.nai.target_type
    config_physical.type = PUDS_MSGTYPE_USDT
    config_physical.nai.source_addr = source_mapping.nai.source_addr
    config_physical.nai.target_addr = source_mapping.nai.target_addr
    config_physical.nai.extension_addr = 0
    ISOTP_REQUEST_MSG = create_string_buffer(6)
    ISOTP_REQUEST_MSG[0]=0x22
    ISOTP_REQUEST_MSG[1]=0x02
    ISOTP_REQUEST_MSG[2]=0x01
    MSG_SIZE = 2
    while 1:
        sleep(0.01)
        msg_request = uds_msg()
        response = uds_msg()
        request_confirmation = uds_msg()
        data_identifier_count = 1
        #data_identifiers = (c_uint16 * data_identifier_count) (0x0101)  #22 01 01
        # Allocate TX message with previous configuration
        tx_msg = uds_msg()
        status = objPCANUds.MsgAlloc_2013(tx_msg, config_physical, MSG_SIZE)
        tx_msg.msg.msgdata.any.contents.data[0]=0x21
        tx_msg.msg.msgdata.any.contents.data[1]=0x01
        #tx_msg.msg.msgdata.any.contents.data[2]=0x01
        print("Allocate TX message: %s" %(STATUS_OK_KO(status)))
        status = objPCANUds.Write_2013(client_handle, tx_msg)
        if objPCANUds.StatusIsOk_2013(status, PUDS_STATUS_OK, False):
            status = objPCANUds.WaitForService_2013(client_handle, msg_request, response, request_confirmation)
            print("WaitForService_2013: %s" %(STATUS_OK_KO(status)))
            #print(response.msg.msgdata.any.contents.data[0])
            message_data = bytes(response.msg.msgdata.any.contents.data[:response.msg.msgdata.any.contents.length])
            byte_list = [f'{byte:02x}' for byte in message_data]
            print(byte_list)
            print(f"0x{response.msg.can_info.can_id:x}")
os.add_dll_directory(os.getcwd());
# UDS library
objPCANUds = PCAN_UDS_2013()
# Definitions
BUFFER_SIZE = 256
# Main entry point of the program, start a UDS channel, ask in the same time UDS TesterPresent and isotp request
# Initialize variables
client_handle = PCANTP_HANDLE_USBBUS1 # TODO: modify the value according to your available PCAN devices.
#t_params = task_params()
#t_params.client_handle = client_handle
#t_params.stop_task = False
# Print version informations
buffer = create_string_buffer(BUFFER_SIZE)
status = objPCANUds.GetValue_2013(PCANTP_HANDLE_NONEBUS, PUDS_PARAMETER_API_VERSION, buffer, BUFFER_SIZE)
print("PCAN-UDS API Version - %s: %s" %(buffer.value, UDS_STATUS_OK_KO(status)))
# Initialize client channel
status = objPCANUds.Initialize_2013(client_handle, PCANTP_BAUDRATE_500K, 0, 0, 0)
print("Initialize channel: %s" %(UDS_STATUS_OK_KO(status)))
ThreadWorking=threading.Thread(target=ThreadWork)
ThreadWorking.start()
ThreadWorking.join()
objPCANUds.Uninitialize_2013(client_handle)
** changed by ADMIN - see Forum Rules - ALWAYS format if you post source code **
Post by K.Wagner » Fri 28. Jun 2024, 08:59
Dear,
Please understand that neither the companion development of software nor teaching protocols and standards is part of the scope of support that we offer for the libraries. My colleague has already helped you beyond the scope of our support. If you can use the services of our APIs and send messages, then the problem is more likely with the configuration of your ECU. Please check its documentation and also the UDS documentation regarding the services you are using. Note that the standards (ISO-TP and UDS protocol descriptions) are not part of our documentation. in case you do not have these, they can be purchased via the ISO online shop.
Thank you for your understanding.
