internal termination (serial number >200.00)
Should the internal termination (serial number >200.00) be executed using a soldered jumper or a 120 Ohm surfaceslope mount resistor? Thank you.
Re: internal termination (serial number >200.00)
We would recommend using termination adaptors, as they are more flexible
and there is less danger over overtermination.
BR
BR
In Addition:
Those are solder bridges, the 120 Ohms are present on the board, so to acitvate termination soldering the bridges
is sufficent.
BR
Marv
is sufficent.
BR
Marv
