UDS: implementation custom function working 4959 time but not more
Benoit_V
Post by Benoit_V » Thu 7. Nov 2024, 15:40
I try to implement a custom service to transfert a custom data via UDS protocol.
My data takes 15 CAN frames to transfert (in consequence multiframe)
All works good during almost 4959 exchanges but in the number 4960 the software crashes.
And I don't understand why? What's wrong with my code.
I'm thinking a trouble inside the function: UDS_Read_2013()?
Or an internal variable not reinitialised.
I have updated this week with the latest:
- PCAN-BASIC.
- PCAN-UDS.
- PCAN-ISO-TP.
- PEAK CAN drivers
My code is:
Function
bool uds::requestDatalog()
    uds_status status;
    uds_msg _msg_write;
    uds_msg response;
    uds_msg confirmation;
    uds_msg loopback_msg;
    bool _function_return = false;
    QString var_debug="";
    cantp_handle channel = s_tp_handle;
    uds_msgconfig config = s_config_physical;
    memset(&response, 0, sizeof(uds_msg));
    memset(&confirmation, 0, sizeof(uds_msg));
    memset(&_msg_write, 0, sizeof(uds_msg));
    memset(&loopback_msg, 0, sizeof(loopback_msg));
    //qDebug() << "\n*** UDS Service: requestDatalog ***\n";
    memset(&config, 0, sizeof(uds_msgconfig));
    config.can_msgtype = PCANTP_CAN_MSGTYPE_EXTENDED;
    config.nai.protocol = PUDS_MSGPROTOCOL_NONE;//PUDS_MSGPROTOCOL_ISO_15765_2_11B_NORMAL;
    config.nai.target_type = PCANTP_ISOTP_ADDRESSING_PHYSICAL;
    config.type = PUDS_MSGTYPE_UUDT;
    status = UDS_MsgAlloc_2013(&_msg_write,config,8);
    //qDebug() << "status alloc msgwrite = " << status;
    status = UDS_MsgAlloc_2013(&response,config,8);
    //qDebug() << "status alloc response = " << status;
    //msg_request.msg.msgdata.any->flags = PCANTP_MSGFLAG_ISOTP_FRAME;
    _msg_write.msg.can_info.can_id = (uint32_t)CAN_ID_UDS_REQUEST;
    _msg_write.msg.type = PCANTP_MSGTYPE_CAN;
    _msg_write.msg.msgdata.isotp->length = (uint32_t)8;
    _msg_write.msg.msgdata.isotp->data[0] = (uint8_t)2;
    _msg_write.msg.msgdata.isotp->data[1] = (uint8_t)0xBA;
    _msg_write.msg.msgdata.isotp->data[2] = (uint8_t)0x02;
    if(s_datalog_current_record_number >= 4959)
        qDebug() << "BreakPoint !!! ";
    _function_return = sentAloneUDSRequest(channel,&_msg_write,&response);
    qDebug() << " position = " + QString::number(s_datalog_current_record_number) + "\n";
    if(_function_return == true)
        //qDebug() << "All is ok, start decode data";
        printf(" Tout s'est bien passé, on peut décoder la trame.  \n ");
        fflush(stdout);
        printf(" response.msg.msgdata.isotp length = %d  \n ", response.msg.msgdata.isotp->length);
        fflush(stdout);
        printf(" response.msg.msgdata.isotp->data[0] = %d  \n ", response.msg.msgdata.isotp->data[0]);
        fflush(stdout);
        printf(" response.msg.msgdata.isotp->data[1] = %d  \n ", response.msg.msgdata.isotp->data[1]);
        fflush(stdout);
        if((response.msg.msgdata.isotp->data[0] == 0xFA) && (response.msg.msgdata.isotp->data[1] == 0x02))
            s_datalog_current_record_number++;
			// DATA PROCESS
        else
            var_debug = "\nERROR: Request a record has been failed: Service not iniialized or not data available.\n";
            emit valueChanged(var_debug);
    else
        var_debug = "\nERROR: Request a record has been failed: No response.\n";
    status = UDS_MsgFree_2013(&_msg_write);
    //printf(" Free request message: %i\n", status);
    status = UDS_MsgFree_2013(&response);
    //printf(" Free response message: %i\n", status);
    status = UDS_MsgFree_2013(&confirmation);
    //printf(" Free confirmation message: %i\n", status);
    status = UDS_MsgFree_2013(&loopback_msg);
   // printf(" Free loopback_msg message: %i\n", status);
    return _function_return;
Function
bool uds::sentAloneUDSRequest(cantp_handle channel, uds_msg *_msg_write, uds_msg *response)
    bool _ret = false;
    TPCANStatus     _status_result = (TPCANStatus)PUDS_STATUS_OK;
    uds_status status;
    uint32_t _timeout_recep = 0;
    uds_msg _uds_temp;
    uint32_t test_id_frame = 0;
    memset(&_uds_temp, 0, sizeof(uds_msg));
    _status_result = (TPCANStatus)UDS_Write_2013(channel,_msg_write);
    status = (uds_status)_status_result;
    //qDebug() << "UDS_Write_2013 1  =  " << status << "\n";
    _timeout_recep = 0;
    while((test_id_frame != CAN_ID_UDS_ANSWER && (_timeout_recep < TIMEOUT_MAX_RECEPTION_FRAME)))
        status = UDS_MsgFree_2013(&_uds_temp);
        _status_result = UDS_Read_2013((cantp_handle)channel,&_uds_temp,NULL,NULL);
        tempo_ms(TEMPO_BETWEEN_TEST_MS,qApp);
        _timeout_recep++;
        test_id_frame = _uds_temp.msg.can_info.can_id;
    _uds_temp.msg.can_info.can_id = 0;
    qDebug() << "Sortie while";
    if(_timeout_recep < TIMEOUT_MAX_RECEPTION_FRAME)    // Tout s'est bien passé, on peut continuer
        if(_uds_temp.msg.msgdata.isotp->length > 7)  // Multiframe
            //qDebug() << "Trame sur du multiframe !!!";
            printf("Trame sur du multiframe !!! \n ");
            fflush(stdout);
            _timeout_recep = 0;
            while((_uds_temp.msg.can_info.can_id != CAN_ID_UDS_ANSWER && (_timeout_recep < TIMEOUT_MAX_RECEPTION_FRAME)))
                //qDebug() << "Status result 1 = " << _status_result << "  ---  UDS_Read_2013 reponse ID  1 =  " << response.msg.can_info.can_id;
                _timeout_recep++;
        else
            printf("Single frame !!! \n ");
            fflush(stdout);
            printf("_uds_temp.msg.msgdata.isotp->length = %d \n ", _uds_temp.msg.msgdata.isotp->length);
            fflush(stdout);
            response->msg.msgdata.isotp->length =_uds_temp.msg.msgdata.isotp->length;
            response->msg.msgdata.isotp->data = _uds_temp.msg.msgdata.isotp->data;
            _ret = true;
        else
            qDebug() << "Erreur alone function timeout ";
    else
    return _ret;
Thank you for your help !!!
Reason: Code formatted for better reading
F.Vergnaud
Re: UDS: implementation custom function working 4959 time but not more
Post by F.Vergnaud » Fri 8. Nov 2024, 14:47
From your code it feels like you're sending a UDS request and expects multiple UDS responses ?! (in sentAloneUDSRequest, there is while loop around UDS_Read_2013(...)).
This is not valid UDS communication: a physical UDS request is answered by only one UDS response. A UDS message handles segmentation which is done by the ISO-TP layer.
This means that you don't have to handle each segmented frames.
Even with a custom service, you should use UDS_WaitForService_2013 to read the response of a request. You should check the samples (06_client_all_request) to see how to use WaitForService function.
Regarding your crash, you access "_uds_temp.msg.msgdata.isotp" without checking if uds_temp.msg is actually a message with the type PCANTP_MSGTYPE_ISOTP:
* msgdata is a union, it can store either a CAN frame, CAN FD frame or ISOTP message.
* there will be an access exception if you access isotp information in a can/canfd object...
Benoit_V
Post by Benoit_V » Thu 14. Nov 2024, 17:49
I have adapted my code to use the UDS_WaitForService_2013.
I have saw the example inside the client all request.
Unfortunately, my code doesn't work.
With the uds_status, I have an error (PCANTP_ERRSTATUS_MAPPING_INVALID = 0x0EU) and I don't understood why.
Do you have an idea?
I use the function UDS_Write_2013 to send the uds request. It's the good process?
Thank for your help!
    bool _ret = false;
    uds_status status;
    uds_msg _uds_temp;
    uds_msg request;
    uds_msg local_response;
    memset(&request, 0, sizeof(uds_msg));
    memset(&local_response, 0, sizeof(uds_msg));
    uds_mapping request_mapping = {};
//    request_mapping.can_id = CAN_ID_UDS_REQUEST;
    request_mapping.can_id_flow_ctrl = CAN_ID_UDS_REQUEST+1;
    request_mapping.can_msgtype = PCANTP_CAN_MSGTYPE_EXTENDED;
    request_mapping.nai.extension_addr = 0;
    request_mapping.nai.protocol = PUDS_MSGPROTOCOL_ISO_15765_2_29B_FIXED_NORMAL;
    request_mapping.can_tx_dlc = 8;
    request_mapping.nai.source_addr = PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
    request_mapping.nai.target_addr = PUDS_ISO_15765_4_ADDR_ECU_1;
    request_mapping.nai.target_type = PCANTP_ISOTP_ADDRESSING_PHYSICAL;
    status = UDS_AddMapping_2013(channel, &request_mapping);
	qDebug() << "Status Mapping = " << status;
    _status_result = UDS_WaitForService_2013(channel, _msg_write, &local_response, &confirmation);
    qDebug() << "Status wait for service = " << _status_result;
    status = UDS_MsgFree_2013(&request);
    status = UDS_MsgFree_2013(&local_response);
    qDebug() << "FIN alone function ";
    return _ret;
Reason: Inserted [code] tag for improved readability
F.Vergnaud
Post by F.Vergnaud » Fri 15. Nov 2024, 11:13
First of all in your code, you first write a message (UDS_Write) then call UDS_AddMapping. This is wrong: Initialization and configuration must be done only once and before any communication.
You want to communicate using 29 bit Fixed normal addressing, this network addressing information does not require a mapping (CAN ID contains the source/target information) as stated in the PCAN-UDS documentation in §4.3
"UDS and ISO-TP Network Addressing Information".
You can check example "12_client_request_ReadDataByPeriodicIdentifier" for a code sample.
To help you further, here is a draft on how your code should look like (please check the inline comments):
main_function(...)
    // configure a UDS request 29 bit Fixed Normal, CHANGE source and target address
    config.can_id = -1;
    config.nai.protocol = PUDS_MSGPROTOCOL_ISO_15765_2_29B_NORMAL;
    config.type = PUDS_MSGTYPE_USDT;
    config.nai.source_addr = 0x10; //TODO change
    config.nai.target_addr = 0x20; //TODO change
    uds_status status = UDS_MsgAlloc_2013(_msg_write, config, size); // CANTP Alloc + Init
    if (UDS_StatusIsOk(status)) {
        // configure data
         // write and read response
    bool _ret = false;
    uds_status status;
    status = (TPCANStatus)UDS_Write_2013(channel,_msg_write);
    // assert status is OK before trying to read response
        status = UDS_WaitForService_2013(channel, _msg_write, response, &confirmation);
        // assert status is OK, you should also check confirmation (especially result status)
        _ret = UDS_StatusIsOk(status);
        qDebug() << "Status wait for service = " << status;
    return _ret;
Benoit_V
Post by Benoit_V » Mon 25. Nov 2024, 13:04
I had use your code. Unfortunately, the problem is still there.
I had discuss with my colleagues and after some tests. We thinking a trouble inside the function UDS_MsgFree_2013() but we are not sure.
To solve our problem, do you have an example for implementation or a precise description for one of your internal function, like par exemple, UDS_SvcECUReset_2013, please?
Best regard.
F.Vergnaud
Post by F.Vergnaud » Mon 25. Nov 2024, 15:03
You can check sample 01 where the sample writes the response to ECUReset request.
This is similar to what is is done internally, here is an overview:
// Used by the client to request a server reset
uds_status SvcECUReset_2013(cantp_handle channel, uds_msgconfig request_config, uds_msg *out_msg_request, uint8_t reset_type)
    const uint32_t size = 2;
    uds_status status = UDS_MsgAlloc_2013(out_msg_request, request_config, size);
    if (UDS_StatusIsOk_2013(status))
        *out_msg_request->links.service_id = PUDS_SI_ECUReset;
        out_msg_request->links.param[0] = reset_type;
        status = UDS_Write_2013(channel, out_msg_request);
    return status;
If you think you found an issue, please contact support at peak-system.com mentioning this thread and attach a minimal and working sample showing the problem.
Benoit_V
Post by Benoit_V » Wed 27. Nov 2024, 16:11
I use your function "uds_status uds::SvcECUReset_2013" and it's work.
I have adaptated to my function.
But unfortunately, it's doesn't work.
Do you have an example with a function with a multiframes, please?
F.Vergnaud
Post by F.Vergnaud » Wed 27. Nov 2024, 16:33
Simply change size to a value greater than 7 and copy some data in the buffer:
    // add some data to the UDS request
    uint8_t data[20];
    memset(data, 0xAB, sizeof(data));
    const uint32_t size = 2 + sizeof(data);
        // copy data
        memcpy(&out_msg_request->links.param[1], data, sizeof(data));
    return status;
Benoit_V
Post by Benoit_V » Mon 9. Dec 2024, 09:32
After some tests, we have found the problem.
The problem was a recursive function to call the UDS Function.
No problem inside the library.
Thank you for help!!
