Slave response with still-alive counter
LIN Interface for USB
Guido
Post by Guido » Mon 13. Jan 2025, 15:45
Hi, is there an example on how to send an automatic slave response to a defined master ID which contains a 4 or 8 bit counter incrementing 1 with every message? Thank you :D
Re: Slave response with still-alive counter
Post by M.Maidhof » Tue 14. Jan 2025, 09:55
there is no example available for that, but you can setup a slave node application with PLIN-API, and change the publisher data after you have received the last publisher frame with LIN_Read(). In that case each successful read will be the trigger to increase your counter.
