CAN_SetValue returns Unknown Error
phyllostachys
Post by phyllostachys » Thu 8. May 2025, 19:49
I was trying to implement the event system on Windows in a Rust library that wraps the PCANBasic API. I only get back Unknown Error (0x10000) whenever I make this call. Snippet of code looks like this, copying from the C++ example.
                // HANDLE iBuffer = CreateEvent(NULL, FALSE, FALSE, L"");
                let event_handle: windows::Win32::Foundation::HANDLE =
                    unsafe { CreateEventA(None, false, false, s!("")).unwrap() };
                // TPCANStatus stsResult = CAN_SetValue(PcanHandle, PCAN_RECEIVE_EVENT, &iBuffer, sizeof(iBuffer));
                let status: PcanStatus = unsafe {
                    dbg!(PCAN_LIBRARY.CAN_SetValue(
                        channel,
                        PCAN_RECEIVE_EVENT as u8,
                        event_handle.0,
                        std::mem::size_of::<windows::Win32::Foundation::HANDLE>() as u32,
                        // std::mem::size_of_val(&event_handle) as u32,
                }.into();
PCAN_LIBRARY is just a struct with function pointers loaded from the DLL. channel is just the usual PCAN_USBBUS2 (0x52). The HANDLE in the windows crate is just a thin wrapper around a usual void pointer (that's what's returned by the .0 notation).
Is there anything obvious that I'm doing wrong?
Re: CAN_SetValue returns Unknown Error
Post by K.Wagner » Fri 9. May 2025, 07:55
as we (still) do not work or know Rust programming, it is difficult to say something about the construtct of your code, but for us it looks like you would use the value of the event handle and not a reference to it.
Additionally, an ERROR_UNKNOWN is normally returned, when an internal exception is rised. If you activate the log functionality (PCAN_LOG_STATUS), then you should see an entry for the exception when it coccurrs and a WIndows error code. This should help you further to find the problem.
phyllostachys
Post by phyllostachys » Fri 9. May 2025, 20:39
While trying to enable logging, I realized that Buffer is supposed to be the address of the thing storing the parameter setting. I think I got hung up because it's a void pointer and the thing we were trying to pass in is a void pointer. It's obvious why this is wrong when you are trying to set something that's just a value using the PCAN_SetValue function (such as PCAN_LOG_STATUS to PCAN_PARAMETER_ON).
                        channel,
                        pcan_sys::PCAN_RECEIVE_EVENT as u8,
                        addr_of_mut!(event_handle.0) as *mut c_void,				//  <-- get address of HANDLE, which is a void** and we further cast it as just a void*
                        std::mem::size_of::<windows::Win32::Foundation::HANDLE>() as u32,	// still works!
                .into();
Post by K.Wagner » Mon 12. May 2025, 09:20
ok, this is what I stated in my last post:
But, I cannot understand from your code if it is working now or not? despite of this, please note, that what the function expects is a "buffer", meaning, the value you want to set as a reference (the address of a variable containing the needed value).
There are already one or two wrappers for PCAN-Basic for Rust in the internet (not from PEAK). Maybe you want to use one of them? For example, peak-can-sys
