John Linq
Post
by John Linq » Fri 6. Jun 2025, 03:21
Hello everyone,
I need help understanding how to write this macro/script in PCAN-Explorer 6:
Dim RcvMsg, TxMsg
Set RcvMsg = MyClient.Messages.Add
Set TxMsg = MyClient.Messages.Add
With TxMsg
.ID = &H220
.DLC = 10 ' 16 Bytes
.MsgType = pcanMsgTypeFD + pcanMsgTypeBRS
' fill data
Dim i
For i = 0 To 7
.Data(i) = i + &H10 ' i = 7 is OK, i > 7 just doesn't work
Next
End With
.Data(i) how to fill all 16bytes?
- Support
Post
by G.Lang » Fri 6. Jun 2025, 13:14
please send us an email which include your PCAN-Explorers license ID and referr to this forum post.
K.Wolf
- Software Development
Post
by K.Wolf » Tue 10. Jun 2025, 14:03
To resolve this, first set the MsgType, then the DLC.
In your example, when you set the DLC to 10, the message is still a classic CAN message, for which a DLC value of 10 is allowed (although not recommended) but it still means a data length of 8 bytes. The internal data buffer is allocated accordingly.
When you then change the message type to FD in the next line, the internal data buffer is not reallocated. But if you set the DLC after MsgType, the internal data buffer is allocated with the correct size 16.
