PCAN-Diag and user defined Bitrates
Handheld CAN Bus Diagnostics Unit - Version 1
Post by PEAK-Support » Fri 11. Feb 2011, 16:06
The PCAN-Diag have a lot of predefined Bitrates to select in the Device Settings menue. But sometimes you need a special Bitrate that is not listed. What to do :?:
Here the solution:
1. Download the BTR-CAN Bitrate calculation Software from our Download page: BaudTool
2. Start the Software and type your needed Bitrate into the BaudRate box
3. press calculate to see if a bitrate could be found for your settings.
3. You will see the values for the user defined Bitrate and could select the values that fit to your need.
(sample point etc.)
BTRCAN Sample
BTRCAN Sample
4. On the PCAN-Diag set CAN Bitrate to User
5. Type the BTR0/BTR1 values into the User CAN Bitrate (hex) settings (in our sample it is 3F11 for 25K with a samplepoint of 60%)
Now you could use the PCAN-Diag with a Bitrate of 25KBit :D
