Hi!
I'm using PCAN-USB on a Bus CAN, PCAN-USB work very well with my network because i can see the messages receive and transmit on the tab trace. I would like to transmit messages automaticaly maybe upload a file of my computer. i know that i can create a new message directly on the application but i would like to send more data automatically.
I would like to know if exist another way to transmit this data or if i have to create a program on another software and then link with software PCAN-view?
Thank you
Karol
Transmit more Data automatically on PCAN-View
Re: Transmit more Data automatically on PCAN-View
You could use the PCAN-Basic API to build your own Application in C/C++/C#/Delphi/VB.Net/Phyton/Java etc.
You will find well documented samples, and Documentation in this packages to help you to start with your project. There are also other Software available which works fine with our CAN Hardware.
Thank you for your reponse
When you said that "other Software available which works fine with our CAN Hardware" which software it is available?
See Third Party Software section in the forum: http://www.peak-system.com/forum/viewforum.php?f=116
