Building c# sample plugin
I am experimenting with the C# plugin sample that ships with PCAN Explorer 5.
I converted the project to Visual C# 2010 Express (just the normal convert project option built into VC#). The project built without any errors or warnings. I copied the DLL to the PCAN plugins folder but the plugin was not recognised in the Add-In Manager. I tried browsing to the DLL from the Add-In Manager and got the message that the DLL file does not contain a PCAN Explorer Addin.
Can you please shed some light on what the problem might be?
Re: Building c# sample plugin
Please also copy the file Interop.PCANExplorer5.dll that was created in the project's output directory to the Addins folder and open the Add-in Manager again.
Thanks for the quick response. I tried copying both AddInSample.dll and Interop.PCANExplorer5.dll to the Plugins directory with no success. I also tried using the Browse feature of the Add-In Manager and got the same message about the DLL not containing a PCAN Explorer Addin.
Do you have any other suggestions?
Just to clarify, I am using Window 7 on a 64 bit Intel platform.
After testing this under Windows 7 64-bit I got the same problem. I had to make minor adjustments to the source code to get it working:
1) Remove the stdole reference from the project
2) In Commands.cs, in the line "public interface IExampleCommands: stdole.IDispatch" remove all text behind IExampleCommands, including the colon.
Now clean the project and rebuild all, then copy both files to the Addins folder again. Make sure that you run PCAN-Explorer as Administrator, then open the Add-in Manager.
I am still getting the same message.
I assume when I run the Add-In manager in administrator mode I should see the AddInSample listed? If I use Browse in the Add-In manager I get the same message about not the file not containing a PCAN plugin.
Would it be possible to post your project so I can be sure there is nothing else different?
Richard
P.S. Looking at the first few bytes of the file, I notice that other plugins start with MZP and contain the string "This program must be run under Win32" whereas the plugins I have built begins with MZ and contains the string "This program cannot be run in DOS mode".
To aid in debugging I have attached my project.
Richard
- PCANPlugin.zip
- Original project but converted to C sharp Express with mods specified in earlier post
- (22.5 KiB) Downloaded 574 times
The problem is you changed the project to use .NET Framework 4 instead of v2.0. Hosting a managed .NET 4 assembly in a Win32 application is a completely different thing and is currently not supported in PCAN-Explorer. We already experimented with this, but we have not yet succeeded.
Please switch the project back to .NET 2.0 and it will work. We hope to make PCAN-Explorer compatible with .NET 4 in a future release.
Thank you, it now works. After converting from C# 2008 to 2010 I didn't think to check the .Net framework version. For anybody else who is interested, I have attached the now working project for Visual C# 2010 Express.
Richard
Richard
- PCANPlugin.zip
- Working plugin sample for Visual C# 2010 Express
- (22.64 KiB) Downloaded 601 times
I am almost there but not quite!
I have modified the C# plugin source code that is supplied with PCAN Explorer 5 and it all works fine on my machine. In the end I resorted to MSVC# 2008 to build and debug the plugin (you cannot debug a DLL with C# Express). However when my colleague, who has exactly the same specification of PC as me (Windows 7, 64 bit), tries to use the plugin, only a blank tab is displayed. Every time the plugin button is pressed a new empty tab is displayed. I have also built the unmodified sample with exactly the same effect.
UPDATE: I forgot the stole stuff earlier in the thread and it now works fine - not sure why it works on my machine though!
Unfortunately there is still a problem.
Most of my users are fine but on one machine which is to all intents and purposes the same as the others, only a blank tab is displayed when the plugin is started. Based on debug statements I can see that the plugin installed correctly.
What would cause the window not to be displayed?
Richard
Richard
After some extensive debugging with Trace outputs it appears the problem was caused by an exception at start-up.
However this has highlighted another problem - how can I change the version of the DLL?
If I change the assembly version information, the plugin fails to work with the symptoms described previously.
Richard
Richard
