Can I use 2 PCI CAN adapters in a Windows based system to give a total of 4 ports?
If so, how will I identify which ports are 1,2,3, and 4.
Using Multiple CAN PCI Adapters
Re: Using Multiple CAN PCI Adapters
yes, this will be possible. The PCI card channel enumeration is depending on the used PCI slot, so the enumeration will be card1-port1, card1-port2, card2-port1, card2-port2 a.s.o. See help files for the PCANBasic API for more details on how to use several channels with our APIs.
