Sorting out CAN messages which are out of timeline.
rchaluva
Post by rchaluva » Tue 18. Jun 2013, 11:37
I am using PCAN-Explorer-5. I wanted to list the messages which are receiving out of there timeline.
For Ex: Message_A has defined to receive every 50ms but some times i receive in 40ms/34ms and so on.
I wanted to evaluate these messages time lines.
I have tried with timeout option but it's not working as i desired. Do i need to write a macro for this? or do i get any straight solution for this in the software itself?
Please help..
Raju
Re: Sorting out CAN messages which are out of timeline.
Post by M.Maidhof » Tue 18. Jun 2013, 12:24
best solution will be to use a VBmacro to check the timings of your messages.
rchaluva
Post by rchaluva » Tue 18. Jun 2013, 12:31
M.Maidhof wrote:Hi,
Thanks Michael, But are you sure we don't have any other methods of doing it?, Because i am not good at VB and having limited time..
Post by M.Maidhof » Tue 18. Jun 2013, 12:40
Hi
you can use the timeout functionality in the symbole file or a VBmacro, or you trace the CAN data, export it to csv (Excel) and use Excel to check for the timings.
rchaluva
Post by rchaluva » Tue 18. Jun 2013, 12:55
M.Maidhof wrote:Hi
I tried Excel sheet, it's time consuming process to check every time.
I have used timeout functionality in Symbol file and got below problem.
I had given timeout time as 2001ms for the message which has to receive every 2000ms. but it displays all the messages in timeout window.
Could you please give a tips on using Timeout please.
You can find attachment for more details.
Raju
PCAN-Timeout functionality
Post by M.Maidhof » Thu 20. Jun 2013, 12:00
which version of PCAN-Explorer 5 do you use? It will be helpfull to send your project to us (also a trace of the data will be helpfull) by email, to check it here on our system. Please use the support email address. Please send you licence number with the email. Thank you.
