Reset timestamps
par.degerman
Reset timestamps
Post by par.degerman » Fri 16. Aug 2013, 11:30
I am seeing ever increasing timestamps even if I restart my application and reinitialize the PCANBasic API. How can I reset the internal clock in the hardware using the api?
Grüß
Pär
Re: Reset timestamps
Post by K.Wagner » Fri 16. Aug 2013, 11:51
the time stamp of a CAN message contains the number of microseconds since the start of Windows. So you have to restart Windows to achieve an internal clock reset :D.
If you want the timestamps to always start with 0 within your application then you have to use a timestamp offset and calculate yourself the time elapsed. You achieve this by substracting the first received timestamp of the last one, each time a message is received.
hmluqman
Post by hmluqman » Tue 25. Aug 2015, 18:42
TS = readResult[2]
        TimeStamp = TS.micros+TS.millis*1000 + 0x100000000 * 1000 * TS.millis_overflow
        print TimeStamp
I am using Python on windows.
I want to calculate the time between two CAN frames on my bus. When I run this code I get following values:
18740080279
18740080537
18740080802
18740081064
If I minus any two consecutive I get around; 262L or 258L
what it means by these '262L or 258L' ?
When I read PCAN_View I get values in thousands. and difference is of 3
1,3600
1,3603
Can you please difference and explain
Post by K.Wagner » Wed 26. Aug 2015, 10:29
hmluqman wrote:TS = readResult[2]
        print TimeStamp
You are calculating here the time stamp of the Frame as the total of microseconds since the start of Windows.
hmluqman wrote:If I minus any two consecutive I get around; 262L or 258L
When you substract one value from the other, you will get the difference in microseconds between those two CAN-frames, i.e. how much time is elapsed between the reception of both. If the times are from frames with same ID, then this is the cycle time of a CAN-Frame (what you see in the Receive pane of PCAN-View). In your example, it would means that the second CAN-frame was received "258 microseconds" after the first one.
hmluqman wrote:When I read PCAN_View I get values in thousands. and difference is of 3
1,3600
1,3603
PCAN-View shows the time, in seconds, that has elapsed since the recording was started, with a resolution of 1/10 Millisecond. In your code you have a difference of 300 microseconds. Since PCAN-View has only one place for the microsecond it may show rounded values.
hmluqman
Post by hmluqman » Wed 26. Aug 2015, 11:32
Thanks a lot for your reply.
Adhara
Post by Adhara » Sat 11. Nov 2017, 10:20
we are working with PCAN basic on Windows and would need to translate the timestamp into an absolute datetime. We are aware that we are potentially losing some precision (the micros) but the question is what time should be used as the reference time. I know it's the last Win reboot, but in .NET we have several ways to retrieve this info. Some take into account sleep time, some do not, so with the experiments so far we got that translating timestamps may end up in a moment (slightly) in the future.
Which is your suggested way? I guess PCAN-View does a similar thing in order to show the elapsed recording time.
Thanks in advance
Adhara
Post by K.Wagner » Mon 13. Nov 2017, 12:21
the Timestamp of CAN messages within PCAN-Basic correspond to the number of microseconds since Window's start.
You should get the absolute time to "Now", substrat the time elapsed since windows start, and add the time represented by the timestamp. That would be the absolute time of the CAN message.
PCAN-View just store the time at when the record starts (DataeTime.Now). Messages times are then relative to that.
jorgz
Post by jorgz » Thu 20. Jun 2024, 09:15
I have managed to obtain the timestamp for the received CAN frames, from PCANBasic. My question is how to also obtain the timestamp of the sent frames, on the PCANBasic on the read function a timestamp is passed:
public static extern TPCANStatus Read(
            [MarshalAs(UnmanagedType.U2)]
            TPCANHandle Channel,
            out TPCANMsg MessageBuffer,
            out TPCANTimestamp TimestampBuffer)
so When I read on my side I can see the value but on the write function:
public static extern TPCANStatus Write(
            ref TPCANMsg MessageBuffer);
There is no timestamp passed. What I want is to be able to log the received and sent messages in a text file with precise timestamp.
** Edit by Admin **
Please see Forum Rules - code need to be Formated
Post by K.Wagner » Thu 20. Jun 2024, 10:07
Timestamps are only available for received messages. If you want to get the timestamp of sent messages, then you can activate the parameter PCAN_ALLOW_ECHO_FRAMES. This causes your applicaiton to read an echo of any sent frame. This echo frame is placed in the receive queue when the message is physically sent, together with the precise sent timestamp. This echo message has to be read then in the same way you get other messages (over the CAN_Read/CAN_ReadFD function) and you recognizes it because the MSGTYPE of the message has the flag PCAN_MESSAGE_ECHO.
jorgz
Post by jorgz » Mon 24. Jun 2024, 09:12
Thanks for the reply, does firmware version 3.2.0 support self receive frames? Im using IPEH-xxxxxx-000411 with 6 usb ports
