Tutorial: Fixed channel assignment with PCAN-PCI devices
Post by G.Lang » Thu 24. Oct 2013, 15:56
IMPORTANT: This does not apply to PCIe based devices anymore.
The references given regarding PCIe based devices are outdated,
please see the following Forum-thread regarding this:
viewtopic.php?f=120&t=5914
When using multiple PCI or PCIexpress based cards on the same machine sometimes it is necessary to fix a net to a specific card/channel independent from the sequence these cards are initialized from the BIOS after power-up. The following steps must be taken to accomplish that:
Each PCI based card has a unique combination of Bus-ID, Device-ID (= Geräte-ID) and channel number. To get the necessary infos please start the PCAN2 icon from the control panel
or start the PCAN-View
With these values it´s possible to create a registry key. Here are an example with 2 PCI cards (one card with 2 channels and Bus ID 7 and one card with 4 channels and Bus ID 6)
The following keys must be created:
"Hardware16"="0x101,6,0,0,0" Note: channel 1 of the 4-channel card
"Hardware15"="0x101,6,0,0,1" Note: channel 2 of the 4-channel card
"Hardware14"="0x101,6,0,0,2" Note: channel 3 of the 4-channel card
"Hardware13"="0x101,6,0,0,3" Note: channel 4 of the 4-channel card
"Hardware12"="0x101,7,0,0,0" Note: channel 1 of the 2-channel card
"Hardware11"="0x101,7,0,0,1" Note: channel 2 of the 2-channel card
scheme: Hardware<handle>=<drivertypecode>,<busnr>,<device>,<function>,<controllernr>
Description of Parameter 1:
Note: The hardware handle for plug-´n-play devices starts with 16 and decrements by 1 with every CAN channel
Hardware16 = HardwareHandle16
Hardware15 = HardwareHandle 15
Hardware8 = HardwareHandle8
Hardware1 = HardwareHandle1
Description of Parameter 2:
0x101 = PCAN-PCI and PCAN-PCIexpress with TundraChip
0x102 = PCAN-ExpressCard
0x104 = PCAN-cPCI
Note: if you are unsure, please contact us via email and tell us your serial number
Description of Parameter 3:
please use the device number form the screenshot above
Description of Parameter 4:
use always "0"
Description of Parameter 5:
0 = Channel 1
1 = Channel 2
2 = Channel 3
3 = Channel 4
after this reboot your computer and verify that your settings were done
guusveek
Re: Fixed channel assignment with PCAN-PCI
Post by guusveek » Thu 15. Jun 2017, 11:14
I have tried this but with no succes
I have 2 PCI cards and 1 PCI express I like to have the 2 PCI cards as channels 1 throuh 4 and the PCI express as channel 5 through 8 now I have PCI card 1 for channels 1 and 2 then the PCI express and last the second PCI card.
I have the following keys defined:
Hardware09 REG_SZ 0x101,3,0,0,3
Hardware10 REG_SZ 0x101,3,0,0,2
Hardware11 REG_SZ 0x101,3,0,0,1
Hardware12 REG_SZ 0x101,3,0,0,0
Hardware13 REG_SZ 0x101,5,2,0,1
Hardware14 REG_SZ 0x101,5,2,0,0
Hardware15 REG_SZ 0x101,5,1,0,1
Hardware16 REG_SZ 0x101,5,1,0,0
But still no change it stays PCI card1 ch 1and 2 then PCI express for 3 through 6 and PCI card 2 for channel 7 and 8.
How to fix this?
Guus
guusveek
Post by guusveek » Thu 15. Jun 2017, 13:46
I got it working had to use 0x103 for the PCI express card and 0x101 for the PCI card.
Guus
Re: Fixed channel assignment with PCAN-PCIexpress
Post by PEAK-Support » Fri 16. Jun 2017, 09:31
that is exact what Gunter wrote in his post:
0x103 = PCAN-PCIexpress without Tundra (FPGA solution)
0x108 = PCAN-miniPCIe
Post by G.Lang » Tue 31. Jul 2018, 15:14
Updated list for parameter 2 (CAN_GetDriverName)
PCI and PCIexpress based cards
0x101 = PCAN-PCI
0x101 = PCAN-PCI Express (the Tundra powered version, sold till ~2014)
0x101 = PCAN-PC/104-Express (the Tundra powered version, sold till ~2014)
0x101 = PCAN-PC/104-Plus
0x106 = PCAN-PC/104-Plus Quad (4-channel version)
0x101 = PCAN-cPCI
0x101 = PCAN-miniPCI
USB based interfaces
0x201 = PCAN-USB
0x201 = PCAN-USB ISO
0x207 = PCAN-USB FD
0x202 = PCAN-USB Pro
0x206 = PCAN-USB Pro FD
0x201 = PCAN-USB Hub
0x209 = PCAN-USB X6
0x208 = PCAN-Chip USB
PC Card based cards
0x401 = PCAN-PC Card
