UDS standard specifies request message for service clearDiagnosticInformation as such:
1B SID
3B DTC
1B memory selection
In Peak's implementation function UDS_SvcClearDiagnosticInformation() accepts only canChannel, MessageBuffer and groupOfDTC, but no memory selection parameter (last byte).
Why is that so?
How should I implement my own clearDiagnosticInformation(), that will accept memory selection parameter as well?
Service clearDiagnosticInformation not fully implemented?
- Software Development
Re: Service clearDiagnosticInformation not fully implemented
Dear ValeV,
PCAN-UDS implements ISO 14229-1:2006 which doesn't mention any "memory selection" parameter for ClearDiagnosticInformation service. Unfortunately it is neither referenced in the 2013 revision...
Which version of the standard do you refer to?
If you want to write a customized request, simply use the UDS_Write function.
Here is a sample (based on example "PCUClient" project) on how to do so:
// Sample to request non standard UDS Service
void testCustomService(TPUDSCANHandle Channel, TPUDSNetAddrInfo N_AI)
TPUDSStatus Status;
TPUDSMsg Message = {};
TPUDSMsg MessageResponse = {};
// initialization
Message.NETADDRINFO = N_AI;
CLEAR_CONSOLE
printf("\n\n*** UDS Service: Custom***\n");
// Sends a Physical Custom Message
printf("\n\nSends a Physical Custom Message: \n");
// Initialize message's DATA
memset(Message.DATA.RAW, 0, sizeof(Message.DATA));
Message.LEN = 4;
Message.DATA.REQUEST.SI = 0x18;
Message.DATA.REQUEST.PARAM[0] = 0xFF;
Message.DATA.REQUEST.PARAM[1] = 0xAA;
Message.DATA.REQUEST.PARAM[2] = 0xBB;
// Transmit message
Status = UDS_Write(Channel, &Message);
if (Status == PUDS_ERROR_OK)
Status = UDS_WaitForService(Channel, &MessageResponse, &Message);
printf(" UDS_Write: %i\n", (int)Status);
displayMessage(&Message, &MessageResponse);
else
displayMessage(&Message, NULL);
waitGetch();
Fabrice
Fabrice
F.Vergnaud wrote:Dear ValeV,
// Sample to request non standard UDS Service void testCustomService(TPUDSCANHandle Channel, TPUDSNetAddrInfo N_AI) { TPUDSStatus Status; TPUDSMsg Message = {}; TPUDSMsg MessageResponse = {}; // initialization Message.NETADDRINFO = N_AI; CLEAR_CONSOLE printf("\n\n*** UDS Service: Custom***\n"); // Sends a Physical Custom Message printf("\n\nSends a Physical Custom Message: \n"); // Initialize message's DATA memset(Message.DATA.RAW, 0, sizeof(Message.DATA)); Message.LEN = 4; Message.DATA.REQUEST.SI = 0x18; Message.DATA.REQUEST.PARAM[0] = 0xFF; Message.DATA.REQUEST.PARAM[1] = 0xAA; Message.DATA.REQUEST.PARAM[2] = 0xBB; // Transmit message Status = UDS_Write(Channel, &Message); if (Status == PUDS_ERROR_OK) Status = UDS_WaitForService(Channel, &MessageResponse, &Message); printf(" UDS_Write: %i\n", (int)Status); if (Status == PUDS_ERROR_OK) displayMessage(&Message, &MessageResponse); else displayMessage(&Message, NULL); waitGetch(); }
Thank you for the code, a variation of it works as I wanted.
