Service clearDiagnosticInformation not fully implemented?
ValeV
Post by ValeV » Mon 21. Oct 2019, 12:29
UDS standard specifies request message for service clearDiagnosticInformation as such:
1B SID
3B DTC
1B memory selection
In Peak's implementation function UDS_SvcClearDiagnosticInformation() accepts only canChannel, MessageBuffer and groupOfDTC, but no memory selection parameter (last byte).
Why is that so?
How should I implement my own clearDiagnosticInformation(), that will accept memory selection parameter as well?
F.Vergnaud
Re: Service clearDiagnosticInformation not fully implemented
Post by F.Vergnaud » Mon 21. Oct 2019, 13:39
Dear ValeV,
PCAN-UDS implements ISO 14229-1:2006 which doesn't mention any "memory selection" parameter for ClearDiagnosticInformation service. Unfortunately it is neither referenced in the 2013 revision...
Which version of the standard do you refer to?
If you want to write a customized request, simply use the UDS_Write function.
Here is a sample (based on example "PCUClient" project) on how to do so:
// Sample to request non standard UDS Service
void testCustomService(TPUDSCANHandle Channel, TPUDSNetAddrInfo N_AI)
	TPUDSStatus Status;
	TPUDSMsg Message = {};
	TPUDSMsg MessageResponse = {};
	// initialization
	Message.NETADDRINFO = N_AI;
	CLEAR_CONSOLE
		printf("\n\n*** UDS Service: Custom***\n");
	// Sends a Physical Custom Message
	printf("\n\nSends a Physical Custom Message: \n");
	// Initialize message's DATA
	memset(Message.DATA.RAW, 0, sizeof(Message.DATA));
	Message.LEN = 4;
	Message.DATA.REQUEST.SI = 0x18;
	Message.DATA.REQUEST.PARAM[0] = 0xFF;
	Message.DATA.REQUEST.PARAM[1] = 0xAA;
	Message.DATA.REQUEST.PARAM[2] = 0xBB;
	// Transmit message
	Status = UDS_Write(Channel, &Message);
	if (Status == PUDS_ERROR_OK)
		Status = UDS_WaitForService(Channel, &MessageResponse, &Message);
	printf("  UDS_Write: %i\n", (int)Status);
		displayMessage(&Message, &MessageResponse);
	else
		displayMessage(&Message, NULL);
	waitGetch();
Fabrice
ValeV
Post by ValeV » Mon 21. Oct 2019, 14:33
F.Vergnaud wrote:Dear ValeV,
	TPUDSStatus Status;
	// initialization
	CLEAR_CONSOLE
	Message.LEN = 4;
	// Transmit message
	else
	waitGetch();
Thank you for the code, a variation of it works as I wanted.
