PCAN Router Pro: Configuration using PCAN-USB Pro
SpeedR
Post by SpeedR » Mon 27. Jan 2020, 22:24
I got a PCAN Router Pro and want to configure it. I am using PCAN-USB Pro (https://www.peak-system.com/PCAN-USB-Pr ... .html?&L=1) to connect to PC.
My questions are regarding the physical connections between the devices and will appreciate any help.
1. How many CAN channels do I need to connect? USB device has 2 and router has 4.
2. Since both devices have male DB-9 connectors, do I just make cables of one-to-one connections with 2 female connectors?
3. Do I need to change internal switch positions or any jumper settings?
4. Is the CF card provided only used for configuration or needs to be inserted at all times?
Re: PCAN Router Pro: Configuration using PCAN-USB Pro
Post by M.Heidemann » Tue 28. Jan 2020, 11:21
First of all take a look athe the user manual here:
For the configuration you only need one active CAN-connection at the first CAN-Channel (CAN1) of the PCAN-Router Pro to one channel of your PCAN-USB Pro. For the PCAN-USB PRO it is not important which of the two channels is used, as long as you specify the right one at configuration.
Yes, exactly , don't forget to add proper termination. Alternatively use termination adapters with unterminated cable (This is more flexible).
Please take a look in the user manual (page 10) to see the pin-layout.
This can be the case if you want to flash your own firmware and need to activate the bootloader of the PCAN-Router Pro.
Information on this can be found in the user manual starting at page 43.
If you just want to use PPCAN-Editor to configure your PCAN Router Pro this is not necessary.
The CF-card is not required. You can use it as storage for logs.
See page 56 of the user manual to see how this is used.
SpeedR
Post by SpeedR » Tue 28. Jan 2020, 15:41
Awesome, will try it soon.
