CAN FD Between PCAN-USB FD and PCAN-USB Pro FD
CAN FD Interface for High-Speed USB 2.0
pdrexel@delta-q.com
Re: CAN FD Between PCAN-USB FD and PCAN-USB Pro FD
Post by pdrexel@delta-q.com » Thu 3. Feb 2022, 18:55
Hi Marvin,
My apologies for breaking any rules of this forum.
I appreciate all your support on this Marvin.
I performed the measurements as discussed in the link viewtopic.php?f=120&t=52 on both adapters and all measurements were 2.47V +/- 0.01V. So, well within the limits, I think. I also tried the settings you posted, but no luck. A shorter cable definitely improves performance, but it's too short to be practical.
Thx,
Pete
Post by M.Heidemann » Fri 4. Feb 2022, 11:07
Can you provide us with a screenshot of the hardware-tab of pcanview for both devices?:
Furthermore, is there any equipment nearby that may causes EMI?
Have you tested in another enviroment yet?
Please let us know.
pdrexel@delta-q.com
Post by pdrexel@delta-q.com » Fri 4. Feb 2022, 18:02
Hi Marvin,
I have turned off everything I can (including the lights) except the PCANView computer. Still no joy.
PCAN USB FD Pro.JPG (40.29 KiB) Viewed 6982 times
PCAN USB FD.JPG (40.05 KiB) Viewed 6982 times
Post by PEAK-Support » Fri 4. Feb 2022, 18:21
Hi Pete, i think it is a wrong timing setup. Lets try this values on both Devices and check if it works:
Please use the latest Version of PCAN-View (part of the Setup or download from the Support page)
Check that the tool loaded the latest pre-defined Values (normally it update the datbase by itself)
Use the Recommended CiA1301 Values Pair-03 (1MBit/5 Mit) with the 80Mhz core
That setup works fine with >80% Busload and mixed Message Types with a 2 Meter CAN cable
pdrexel@delta-q.com
Post by pdrexel@delta-q.com » Mon 7. Feb 2022, 18:34
I downloaded the latest PCANView 5.0.1.822 using your link. However, I do not see the "CiA 1301" option in the bit rate preset.
Thx,
Pete
Post by PEAK-Support » Mon 7. Feb 2022, 18:43
Attached the settings
pdrexel@delta-q.com
Post by pdrexel@delta-q.com » Tue 8. Feb 2022, 20:30
Very good, the results have improved markedly. 5 and 8 Mbps are now possible and reliable even using the IPEK-003000 cable.
The secret seems to be dividing the "nominal" bits into more quanta. With a nominal TSEG1 < 10 (80% sample point), the receiver tends to detect quite few stuff errors. However, if I increase the nominal TSEG1 >= 15 the errors go away.
Thank you very much for the help.
Post by PEAK-Support » Wed 9. Feb 2022, 08:05
you are welcome - CAN-FD Bit Timing is a mirical and compared to the "easy" timing of a CAN 2.0a/b Network very difficult to setup.
The Network Topolgy is one of the main thinks that influence the maxumum Data Bitrate in CAN FD.
