Hello
I am using UDSApi.SvcTransferData_2013() and UDSApi.WaitForService_2013() to receive a file from an ECU.
After the first frame, the PC answers [03 0A 0A].
The PC is able to receive an unlimited amount of consecutive frames without delay, I am wondering why BlockSize is 10 and STmin is 10.
Is it possible to change that? I would like to set STmin to 0.
Thanks and regards
Fabio
receiving a multiple-frame transmission from ECU. why 03 0a 0a?
- Software Development
Re: receiving a multiple-frame transmission from ECU. why 03 0a 0a?
Hello Fabio,
What you are seeing is the ISOTP Flow Control Frame, it holds the Block Size and the Minimum Separation Time.
These can be configured with the corresponding parameters: PCANTP_PARAMETER_BLOCK_SIZE and PCANTP_PARAMETER_SEPARATION_TIME.
Fabrice
Fabrice
thanks. it worked.
UInt32 STmin = 0;
Peak.Can.IsoTp.cantp_status cantpres = CanTpApi.SetValue_2016(canport, cantp_parameter.PCANTP_PARAMETER_SEPARATION_TIME, ref STmin, sizeof(UInt32));
