receiving a multiple-frame transmission from ECU. why 03 0a 0a?
fabio.parodi@technoleader.it
Post by fabio.parodi@technoleader.it » Tue 10. May 2022, 17:47
Hello
I am using UDSApi.SvcTransferData_2013() and UDSApi.WaitForService_2013() to receive a file from an ECU.
After the first frame, the PC answers [03 0A 0A].
The PC is able to receive an unlimited amount of consecutive frames without delay, I am wondering why BlockSize is 10 and STmin is 10.
Is it possible to change that? I would like to set STmin to 0.
Thanks and regards
Fabio
F.Vergnaud
Re: receiving a multiple-frame transmission from ECU. why 03 0a 0a?
Post by F.Vergnaud » Tue 10. May 2022, 17:57
Hello Fabio,
What you are seeing is the ISOTP Flow Control Frame, it holds the Block Size and the Minimum Separation Time.
These can be configured with the corresponding parameters: PCANTP_PARAMETER_BLOCK_SIZE and PCANTP_PARAMETER_SEPARATION_TIME.
Post by fabio.parodi@technoleader.it » Sat 14. May 2022, 10:01
thanks. it worked.
        UInt32 STmin = 0;
        Peak.Can.IsoTp.cantp_status cantpres = CanTpApi.SetValue_2016(canport, cantp_parameter.PCANTP_PARAMETER_SEPARATION_TIME, ref STmin, sizeof(UInt32));
