I am trying to view CAN2.0 messages sent from an embedded MCU on PCAN-view. I have a scope connected to the bus decoding CAN frames as well. I have verified that my embedded device can receive messages from PCAN-View, and I have verified that electrically everything is in order (bus levels, time bases).
As part of my testing I have sent a simple message FROM the PCAN-view terminal to the embedded HW and recorded the waveform. Its acked by the embedded HW and i can see it in embedded memory. Thats all good.
I then send the same message (same ID, DLC, payload...) back from the embedded device to PCAN-view. On the scope i can see that the waveform is identical, so I know i'm sending exactly the same message with the same timing. I also see PCAN-view ACK the message. However nothing appears in the Receive/Transmit window.
I have the acceptance filter set to accept everything. I have both embedded and PCAN setup for 125kbs with 80% sample points. How is it possible that PCAN-view acks a message (indicating to me the message validity) but doesnt display anything? Any help/pointers are hugely apprecaited.
Im running PCAN-view 5.0.5.871
I have PCAN-USB HW with firmware 8.3.0 and driver 4.4.0
Screen captures:
Figure 1 shows PCAN sending message (yellow) and embedded acking (blue)
Figure 2 shows embedded sending message (blue) and PCAN acking (yellow)
-Alexander
PCAN-USB: Received messages are acknowlegded but not displayed by PCAN-View
- embedded sending message (blue) and PCAN acking (yellow)
- Figure2.png (1.1 MiB) Viewed 6937 times
- PCAN sending message (yellow) and embedded acking (blue)
- Figure1.png (1.1 MiB) Viewed 6937 times
Re: PCAN-View ACKs but does not display received messages
Please send us
- more information how you setup the PCAN-View connection options
- is the Bus is terminated? If yes how?
- what exact are you see in the PCAN-View Status Line?
- run the Tracer and set Error logging also active - what do you capture?
Hi, information requested below:
(see attached image). Listen-only mode is not checked.
Terminated with a 137Ω resistor on the embedded HW.
"Connected to hardware PCAN-USB, DEvice ID 60h" Bite rate: 125kbit/s Status:OK Overruns: O QXmtFull:0"
I run the tracer, send a CAN message from embedded to PCAN. Nothing is displayed in the trace window. (See attached image)
- PCAN trace showing options.png (37.94 KiB) Viewed 6934 times
- PCAN trace.png (28.59 KiB) Viewed 6934 times
- PCAN connection options.png (52.91 KiB) Viewed 6934 times
Please send a Picture of the used Device (PCAN-USB) to support @peak-system.com showing the serial number ( please do not post here)
solved by bring the PCAN-USB up to date (Firmware)
