There used to be an option in the PeakCPL to reset PCAN-USB: viewtopic.php?f=41&t=2893&p=9996#p9996
But since that is not available anymore I'm wondering how to reset the PCAN-USB now. In the new PEAK Settings I cannot find it.
I'm stuck in PCAN_ERROR_HWINUSE and have to reset the pc now if that happens which is quite annoying.
Erik
Reset PCAN-USB initialized state by software
Re: Reset PCAN-USB initialized state by software
there is an option now in PEAK Settings to close "zombi" PCANBasic clients. This option will only be visible when there is a PCANBasic client active:
please note following things:
- The PEAK-Settings only shows PCAN-Basic "active" connections. If there are none, then you do not see this section in the app.
- If you do not see this section in the App, but you cannot connect to the channel, this is mostly because the channel is occupied by another applicaiton (PCAN-View, PCAN-Explorer, or any other applicaiton using the PCAN-Developer a.k.a CanApi2/4)
Ah ok, I see. Indeed when I have an application open that uses pcanbasic I see the option.
Only issue I now have is when I have the PCAN_ERROR_HWINUSE error I don't see that option, although I am only testing our application that uses pcanbasic. Only option is to reset the pc then. I will investigate a bit further.
Thanx for your explanation.
Erik
Erik
looks like another application is active (could also using a different API). Do you see PCAN-USB LED flashing in that moment? Do you use codesys or a similar product? Check taskmanager for such applications, and remove the autostart of such apps.
You could also contact us by email (support) to send you a tool to check your PC for installed PCAN files.
