CAN-FD Transmitter Delay Compensation
Professional CAN and CAN FD Development Package for Windows®
Murat.Ocakturk
Post by Murat.Ocakturk » Tue 26. Mar 2024, 17:17
Is it possible to configure CAN-FD PCAN device's "Transmitter Delay Compensation" (TDCO, TDCV) using PCAN-developer 4 library?
This value is specified in ARXML file to configure the CAN-FD controller's "data" phase.
Thank you,
Murat
Murat.Ocakturk
Re: CAN-FD Transmitter Delay Compensation
Post by Murat.Ocakturk » Tue 26. Mar 2024, 17:24
Does data_ssp_offset means Transmitter Delay Compensation?
Post by M.Maidhof » Wed 27. Mar 2024, 15:13
at the moment this option is not available in the CAN FD cores from PEAK. The SSP (secondary sample point) is at the same position as the FD bitrate's sample point. If your FD bitrate is 2 Mbit/s with 82% SP, then the SSP is also at 82%.
