PCAN-RP1210
USB to CAN Interface
changjae han
PCAN-RP1210
Post by changjae han » Sat 27. Jul 2024, 17:18
Hello
rp1210 registration is not working. I installed the latest driver, but nothing is confirmed in the gateway. Do you know the cause?
Re: PCAN-RP1210
Post by M.Heidemann » Mon 29. Jul 2024, 08:26
Can you confirm the following:
Are you using the right bitrate?
Is you bus properly terminated? (120 Ohms on both bus ends)
Please let us know.
Re: PCAN-RP1210
Post by M.Heidemann » Mon 29. Jul 2024, 09:56
Also:
Make sure RP1210 API is actually installed:
Peak-DriverSetup (Includes RP12010 API Setup):
https://www.peak-system.com/quick/DrvSetup
All connected devices during installation are automatically registered,
otherwise this can be done manually via PEAK-Settings
changjae han
Re: PCAN-RP1210
Post by changjae han » Mon 29. Jul 2024, 16:15
Thank you for your reply.
I tried what you said and the driver was installed normally.
I have another question.
I am trying to use the danfoss plus+1 program but it does not connect.
Do I need to set something else?
thank youImage
Re: PCAN-RP1210
Post by M.Heidemann » Mon 29. Jul 2024, 16:23
This can only be done using RP1210 A which is not included in the regular RP1210 API, if you need further information,
please contact us at support[at]peak-system.com
changjae han
Re: PCAN-RP1210
Post by changjae han » Mon 29. Jul 2024, 16:37
Thanks for the reply.
Is it that RP-1210-A can't be downloaded?
The website says it has been merged into RP-1210-C.
Thank you.
Re: PCAN-RP1210
Post by M.Maidhof » Mon 29. Jul 2024, 17:04
there are optional RP1210A drivers available. Contact us by email for more details.
