Hello
rp1210 registration is not working. I installed the latest driver, but nothing is confirmed in the gateway. Do you know the cause?
PCAN-RP1210
PCAN-RP1210
- KakaoTalk_20240727_233725990.png (59.9 KiB) Viewed 5703 times
Re: PCAN-RP1210
Can you confirm the following:
Are you using the right bitrate?
Is you bus properly terminated? (120 Ohms on both bus ends)
Please let us know.
Please let us know.
Re: PCAN-RP1210
Also:
Make sure RP1210 API is actually installed:
Peak-DriverSetup (Includes RP12010 API Setup):
https://www.peak-system.com/quick/DrvSetup
All connected devices during installation are automatically registered,
otherwise this can be done manually via PEAK-Settings
Re: PCAN-RP1210
Thank you for your reply.
I tried what you said and the driver was installed normally.
I have another question.
I am trying to use the danfoss plus+1 program but it does not connect.
Do I need to set something else?
thank you![Image]()
thank you
- KakaoTalk_20240729_231536423.png (6.34 KiB) Viewed 5677 times
Re: PCAN-RP1210
This can only be done using RP1210 A which is not included in the regular RP1210 API, if you need further information,
please contact us at support[at]peak-system.com
Re: PCAN-RP1210
Thanks for the reply.
Is it that RP-1210-A can't be downloaded?
The website says it has been merged into RP-1210-C.
Thank you.
Thank you.
Re: PCAN-RP1210
there are optional RP1210A drivers available. Contact us by email for more details.
