Blank Screen with PCAN-View
I am using LPC11c14 microcontroller and I am trying to implement CAN-Open Pogram in ECLIPSE CDT KEPLER Version.
The program is compiling and debugging perfectly but when I connect PCAN-View , it displays a blank screen as my file is not able to show the data for my Program.
Herewith I have attached my main Prog along with my screenshot of my PCAN Output.
How to get the output in PCAN
Thx in advance
- Screenshot
- pcan-view.PNG (56.05 KiB) Viewed 6259 times
Re: Blank Screen with PCAN-View
can´t help you with your microcontroller firmware, but for a simple check if your controller is active on 500k, please send out the defined frame in the PCAN-View transmit section by hiting the space bar. When you will see a busheavy or busoff in the status bar, there is something wrong with your device or cables. Please also check for termination resistors in your CAN cables.
