Blank Screen with PCAN-View
mahalinr
Post by mahalinr » Tue 5. Nov 2013, 11:28
main.c
Progrm
(6.6 KiB) Downloaded 1000 times
Hi
I am using LPC11c14 microcontroller and I am trying to implement CAN-Open Pogram in ECLIPSE CDT KEPLER Version.
The program is compiling and debugging perfectly but when I connect PCAN-View , it displays a blank screen as my file is not able to show the data for my Program.
Herewith I have attached my main Prog along with my screenshot of my PCAN Output.
How to get the output in PCAN
Thx in advance
Screenshot
Screenshot
Re: Blank Screen with PCAN-View
Post by M.Maidhof » Tue 5. Nov 2013, 15:09
can´t help you with your microcontroller firmware, but for a simple check if your controller is active on 500k, please send out the defined frame in the PCAN-View transmit section by hiting the space bar. When you will see a busheavy or busoff in the status bar, there is something wrong with your device or cables. Please also check for termination resistors in your CAN cables.
