PCAN Explorer and GPRS Link
rampinia
Post by rampinia » Sat 5. Mar 2011, 11:53
I have a PEAK GPRS Link module with firmware completly rewritten by myself. I have LOG activity within this module. Is it possibile to have the file format of the *.trc made by PCAN explorer so to use the same format within GPRS Link? doing this I can use PCAN Explorer symbol file to open and export data recorded within GPRS link.
Andrea
Re: PCAN Explorer and GPRS Link
Post by PEAK-Support » Mon 7. Mar 2011, 12:17
Sample of a standard TRACE File (no symbolic Information - RAW CAN):
Trace File (ASCII)
Trace File (ASCII)
The Header:
; is a REMARK for comments, except a $ is follow (STARTTIME/FILEVERSION)
FILEVERSION: please use 1.1 to be compatible with PCAN-Explorer 4/5
STARTTIME: Date and time are handled as a "floating point" value. The integral part of the value is the number of days that have passed since December 30, 1899. The fractional part is fraction of a 24 hour day that has elapsed.
Example
39414.8339742292
39414 indicates the days passed from 30 December 1899, without execute a calculation, it is enough to check with Excel spreadsheet: 28.11.2007
Time calculation 1
Time calculation 1
0.8339742292 represents the fraction of the elapsed day expressed in 24 hours.
When 24 hours are elapsed, the integer part increments of 1 unit.
In one day there are 24 hours, 1440 minutes, 86.400 seconds, 86.400.000 ms.
Time calculation 2
Time calculation 2
Columns description:
* Message Number is a simple Counter
* Time Offset is the Offset in ms from Frame to Start of Trace (see header)
* Type is the Message Type - could be
  • -Rx for received Frames
    -Tx for send Frames - if you like to store this also
    If a RTR is send or Received, in the Data Byte field a RTR is written. Sample:
    2) 7468.9 Tx 0000 8 RTR
* ID is the CAN ID (HEX)
* Data Length Code is the counter of the used the Data Bytes in this frame
* Data could be 0 to 8 single Bytes in HEX
The Trace file is a ASCII Textfile (8Bit character - no unicode).
The Linebreak is a CR (0x0D) and a LF (0x0A)
We do not use Tab - only Space (0x20)
Trace File  - view in HEX Editor
