I regularly need to export a large amount of trace files to CSV. This takes a lot of time (days) because I have to click export or CTRL+E, select all signals, click OK, wait for the export to finish, and export the next file
Question: is it possible to do this automatically? E.g. select multiple files and batch export all of them? This seems like a task much better suited for a machine than a human. It will save me days of work.
Requirement: the output CSV must not have a header, and must have two columns for each signal; one for the time column and the other for the signal data. (--> output must be identical as when I export the files manually).
I have tried using PEAK converter 2, but I did not succeed to get the desired output CSV because it seems not to be possible to apply a symbol file in PEAK converter.
I'm using PCAN Explorer v5.4.0.877.
Thanks and regards,
Rene
