PCAN-USB: build as netdev for kernel 3.13
alexanderg
Post by alexanderg » Mon 14. Nov 2016, 09:38
Hello!
I can not build 'netdev' driver for PCAN-USB device.
The build fails because of CAN_CTRLMODE_FD is not defined in Linux/include/uapi/linux/can/netlink.h. Also I found that a lot of other CAN definitions are lacks in this file.
What is the problem? Can it be "patched"?
'chardev' device can be build without any problems. My full Linux version is:
Linux ubuntu 3.13.0-73-generic #116-Ubuntu SMP Fri Dec 4 15:31:30 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
S.Grosjean
Re: PCAN-USB: build as netdev for kernel 3.13
Post by S.Grosjean » Mon 14. Nov 2016, 14:23
3.13 is an "old" version, in which there were no support for CAN-FD...
If you plan to use the socket-can interface, why don't you use the mainline driver instead? The PCAN-USB is fully supported by the Kernel in this version, so you don't need to build nor install the pcan (peak-linux-driver-x.y) driver.
Plug your PCAN-USB, then type:
$ ip -s -d link show type can
You should see something like:
39: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
    link/can  promiscuity 0
    can state STOPPED restart-ms 0
          pcan_usb: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..64 brp-inc 1
          clock 8000000
          0          0          0          0          0          0
    0          0        0       0       0       0
    0          0        0       0       0       0
Stéphane
— Stéphane
alexanderg
Post by alexanderg » Mon 14. Nov 2016, 14:51
Hi, Stephane,
Thank you for your response. I tried your solution, it does not work, sorry:
>ip -s link show type can
Error: either "dev" is duplicate, or "can" is a garbage.
Probably, something more to be done.
Alex
S.Grosjean
Post by S.Grosjean » Mon 14. Nov 2016, 15:04
No, it looks like you're running an old version of "iproute2" package.
So, first, let's retry with:
$ ifconfig -a
instead.
Stéphane
— Stéphane
alexanderg
Post by alexanderg » Mon 14. Nov 2016, 15:11
I have checked. No "can" interface in "ifconfig -a" output.
Does it mean, that socket CAN interface is not supported?
Alex.
S.Grosjean
Post by S.Grosjean » Mon 14. Nov 2016, 16:42
Hem, strange. let's start from scratch with trying to load the module by hand:
$ sudo modprobe peak_usb
If nothing (no error) displayed, do (be sure that the PCAN-USB is connected to the USB socket!):
$ dmesg | grep peak_usb
Stéphane
— Stéphane
alexanderg
Post by alexanderg » Mon 14. Nov 2016, 16:54
Thank you, Stephane! Now I see 'can0' netdev interface.
I still have an errors ("RTNETLINK answers: Invalid argument") but suppose, its an application problem.
Thank you a lot.
Alex
alexanderg
Post by alexanderg » Tue 15. Nov 2016, 10:23
Hi, Stephane
Sorry for troubling you again.
Now I see can0 interface at 'ifconfig -a' output:
 can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
So it exist now.
I also checked 'ip -details -statistics link show can0' output:
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
    bitrate 0 sample-point 0.000
    tq 0 prop-seg 0 phase-seg1 0 phase-seg2 0 sjw 0
    clock 8000000
    0          0          0          0          0          0
    0          0        0       0       0       0
    0          0        0       0       0       0
As I understood, can0 interface is still unconfigured, so programs cant use it. What shall I do to make it active?
Alex
Reason: Inserted [code] tags for better readability.
Post by M.Maidhof » Tue 15. Nov 2016, 12:40
now you have to configure the device with "ip link set", see SocketCAN documentation:
or see info in our Linux driver manual on page 33.
alexanderg
Post by alexanderg » Wed 16. Nov 2016, 08:12
Michael, Thank you a lot!
Alex
