PCAN-USB: build as netdev for kernel 3.13
Hello!
I can not build 'netdev' driver for PCAN-USB device.
The build fails because of CAN_CTRLMODE_FD is not defined in Linux/include/uapi/linux/can/netlink.h. Also I found that a lot of other CAN definitions are lacks in this file.
What is the problem? Can it be "patched"?
'chardev' device can be build without any problems. My full Linux version is:
Linux ubuntu 3.13.0-73-generic #116-Ubuntu SMP Fri Dec 4 15:31:30 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
- S.Grosjean
- Software Development
Re: PCAN-USB: build as netdev for kernel 3.13
3.13 is an "old" version, in which there were no support for CAN-FD...
If you plan to use the socket-can interface, why don't you use the mainline driver instead? The PCAN-USB is fully supported by the Kernel in this version, so you don't need to build nor install the pcan (peak-linux-driver-x.y) driver.
Plug your PCAN-USB, then type:
You should see something like:
Stéphane
$ ip -s -d link show type can
39: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
link/can promiscuity 0
can state STOPPED restart-ms 0
pcan_usb: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..64 brp-inc 1
clock 8000000
0 0 0 0 0 0
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
Stéphane
— Stéphane
Hi, Stephane,
Thank you for your response. I tried your solution, it does not work, sorry:
>ip -s link show type can
Error: either "dev" is duplicate, or "can" is a garbage.
Probably, something more to be done.
Alex
Alex
- S.Grosjean
No, it looks like you're running an old version of "iproute2" package.
So, first, let's retry with:
instead.
Stéphane
$ ifconfig -a
Stéphane
— Stéphane
I have checked. No "can" interface in "ifconfig -a" output.
Does it mean, that socket CAN interface is not supported?
Alex.
Alex.
- S.Grosjean
Hem, strange. let's start from scratch with trying to load the module by hand:
If nothing (no error) displayed, do (be sure that the PCAN-USB is connected to the USB socket!):
Stéphane
$ sudo modprobe peak_usb
$ dmesg | grep peak_usb
Stéphane
— Stéphane
Thank you, Stephane! Now I see 'can0' netdev interface.
I still have an errors ("RTNETLINK answers: Invalid argument") but suppose, its an application problem.
Thank you a lot.
Alex
Thank you a lot.
Alex
Hi, Stephane
Sorry for troubling you again.
Now I see can0 interface at 'ifconfig -a' output:
So it exist now.
I also checked 'ip -details -statistics link show can0' output:
As I understood, can0 interface is still unconfigured, so programs cant use it. What shall I do to make it active?
Alex
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
bitrate 0 sample-point 0.000
tq 0 prop-seg 0 phase-seg1 0 phase-seg2 0 sjw 0
clock 8000000
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
Alex
Reason: Inserted [code] tags for better readability.
now you have to configure the device with "ip link set", see SocketCAN documentation:
or see info in our Linux driver manual on page 33.
Michael, Thank you a lot!
Alex
Alex
