I have to develop a software to control an balance using PCAN RS232. The balance can be remotely control by using ASCI character in my software. And after the balance having the commands , it will send the weigh as ASCI data, as can see in the picture.
I use PCAN view and then CANape to view the data after transforming the ASCI data. But the problem is the number sent by the balance is float and I don't how to transmit/receive that number in CAN trame and then display it in PCAN view and CANape.
NB: PCAN view version 4.1.1.463
OS Windows 7
In the table, B means Blank.
#include "datatypes.h"
#include "can.h"
#include "can_user.h"
#include "hardware.h"
#include "crc_data.h"
#include "serial.h"
#include "ser_user.h"
#include "eeprom.h"
#include "systime.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
CANMsg_t TxMsg1;
CANMsg_t TxMsg2;
CANMsg_t TxMsg3;
CANMsg_t TxMsg4;
static u32_t outbuf;
// identifier is needed by PCANFlash.exe -> do not delete
const b8_t Ident[] __attribute__ ((used)) = { "PCAN-RS-232"};
// info data for PCANFlash.exe
const crc_array_t C2F_Array __attribute__((section(".C2F_Info"), used)) = {
.Str = CRC_IDENT_STRING,
.Version = 0x21,
.Day = 5,
.Month = 5,
.Year = 6,
.Mode = 1,
// crc infos are patched during link time by flash.ld
// crc value is patched by PCANFlash.exe
// variables for cyclic message transmission
static SYSTIME_t LastCycleMsg;
static CANMsg_t CycleMsg;
// variables for LED toggle
static u8_t LED_toggleCAN1;
b8_t serialDataRead[40] = {0};
//int digit = 0;
u8_t str_serial[40] = {0};
u8_t bytesRead = 0;
u8_t nbData = 0;
int i = 0;
u32_t dataSendCounter;
u8_t select;
u8_t nbChiffre = 0;
u8_t flag_negative = 0;
int Space = 0;
int Digit = 0;
s16_t tmp = 0;
u8_t flag_point = 0;
u8_t flag_invalide = 0;
// main_greeting()
// transmitt a message at module start
static void main_greeting ( void)
CANMsg_t Msg;
Msg.Id = 0x123;
Msg.Len = 8;
Msg.Type = CAN_MSG_STANDARD;
// we will read 8 bytes from eeprom address 100h
EEPROM_Read ( 0x100, &Msg.Data8[0], 8);
// Send Msg
CAN_UserWrite ( CAN_BUS1, &Msg);
// main()
// entry point from crt0.S
int main ( void)
// init hardware
HW_Init();
// init CAN
CAN_UserInit();
SYSTIME_Init();
// init serial
SER_UserInit();
// Set green LEDs for CAN1
HW_SetLED ( HW_LED_CAN1, HW_LED_GREEN);
// send the greeting message
main_greeting();
// main loop
while ( 1)
CANMsg_t RxMsg, TxMsg;
//SYSTIME_t timenow;
// process messages from CAN1
if ( CAN_UserRead ( CAN_BUS1, &RxMsg) != 0)
// message received from CAN1
LED_toggleCAN1 ^= 1;
if ( LED_toggleCAN1)
HW_SetLED ( HW_LED_CAN1, HW_LED_ORANGE);
else
// catch ID 00000250h to send on serial as ascii
if ( RxMsg.Id == 0x250 && RxMsg.Type == CAN_MSG_STANDARD && RxMsg.Data8[0] == 0x77)
SER_ResetTX(SER_PORT1);
SER_Write ( SER_PORT1, "w", 1);
//select = 3 ;
if(RxMsg.Id == 0x250 && RxMsg.Type == CAN_MSG_STANDARD && RxMsg.Data8[0] == 0x74)
SER_Write ( SER_PORT1, "t", 1);
if(RxMsg.Id == 0x250 && RxMsg.Type == CAN_MSG_STANDARD && RxMsg.Data8[0] == 0x75)
outbuf = 1; // and write this with
HW_SetDOUT (&outbuf); // then the rightmost port is set (=Dout-0)
if(RxMsg.Id == 0x250 && RxMsg.Type == CAN_MSG_STANDARD && RxMsg.Data8[0] == 0x76)
outbuf = 0; // and write this with
HW_SetDOUT (&outbuf); // then the rightmost port is set (=Dout-1)
// catch ID 611h to send on serial as binary
else if ( RxMsg.Id == 0x211 && RxMsg.Type == CAN_MSG_STANDARD)
SER_Write ( SER_PORT1, &RxMsg.Data8[0], RxMsg.Len);
// catch ID 48Ah from CAN1 to save new data to the eeprom
else if ( RxMsg.Id == 0x48A && RxMsg.Type == CAN_MSG_STANDARD)
// write new data to eeprom. Next power cycle will show a modified
// greeting message.
EEPROM_Write ( 0x100, &RxMsg.Data8[0], 8);
EEPROM_FlushCache();
else
// copy message and modify
TxMsg.Id = RxMsg.Id + 2;
TxMsg.Type = RxMsg.Type;
TxMsg.Len = RxMsg.Len;
// copy data
TxMsg.Data32[0] = RxMsg.Data32[0];
TxMsg.Data32[1] = RxMsg.Data32[1];
// overwrite byte 0
TxMsg.Data8[0] = 0x55;
// echo back the message for debug
// CAN_UserWrite ( CAN_BUS1, &TxMsg);
// if (SYSTIME_DIFF (dataSendCounter, SYSTIME_NOW) >= 10 ){
switch(select){
case 0:{
TxMsg1.Id = 0x200; //premiere parti du message
TxMsg1.Type = CAN_MSG_STANDARD;
TxMsg1.Len = 8;
CAN_UserWrite ( CAN_BUS1, &TxMsg1);
break;
case 1:{
TxMsg2.Id = 0x201; //deuxieme parti du message
TxMsg2.Type = CAN_MSG_STANDARD;
TxMsg2.Len = 8;
CAN_UserWrite ( CAN_BUS1, &TxMsg2);
break;
case 2:{
TxMsg3.Id = 0x202; //Nombre d'octet lu
TxMsg3.Type = CAN_MSG_STANDARD;
TxMsg3.Len = 2;
CAN_UserWrite ( CAN_BUS1, &TxMsg3);
break;
case 3:{
TxMsg4.Id = 0x206; // Balance 4
TxMsg4.Type = CAN_MSG_STANDARD;
TxMsg4.Len = 8;
//TxMsg4.Data32[0] = poids;
CAN_UserWrite ( CAN_BUS1, &TxMsg4);
break;
default :{
break;
//select++; // seulement pour debug
select = 3 ;
SER_Read(SER_PORT1, &serialDataRead[0], 18, &bytesRead );
nbData = bytesRead;
for(i=0;i<=bytesRead;i++)
if(i<8){
TxMsg1.Data8[i] = serialDataRead[i];
else if((i>7) && (i<16))
TxMsg2.Data8[i-8] = serialDataRead[i];
else
TxMsg3.Data8[i-16] = serialDataRead[i];
str_serial[i]= serialDataRead[i];
if (str_serial[i]== 0x2D)
flag_negative = 1;
Space = 1;
//Digit--;
else
//flag_negative = 0;
for(i = 1; i <=18; i++)
if(serialDataRead[i] == 0X20 && Digit == 0)
Space ++;
if(serialDataRead[i] > 0x2F && serialDataRead[i] < 0x40)
Digit ++ ;
if(serialDataRead[i] == 0x2E)
flag_point = i ;
switch(Digit){
case 5:
tmp = 0;
tmp = (serialDataRead[Space+1]- 48)* 10000 ;
tmp = tmp + (serialDataRead[Space+2]- 48) * 1000;
tmp = tmp + (serialDataRead[Space+3]- 48) * 100;
tmp = tmp + (serialDataRead[Space+4]- 48) * 10;
tmp = tmp + (serialDataRead[Space+5]- 48) * 1;
break;
case 4:
tmp = 0 ;
tmp = tmp + ((serialDataRead[Space+1]- 48) * 1000 );
tmp = tmp + (serialDataRead[Space+2]- 48) * 100;
tmp = tmp + (serialDataRead[Space+3]- 48) * 10;
tmp = tmp + (serialDataRead[Space+4]- 48) * 1;
break;
case 3:
tmp = 0 ;
tmp = (serialDataRead[Space+1]- 48) * 100;
tmp = tmp + (serialDataRead[Space+2]- 48) * 10;
tmp = tmp + (serialDataRead[Space+3]- 48) * 1;
break;
case 2:
tmp = 0;
tmp = (serialDataRead[Space+1]- 48) * 10;
tmp = tmp + (serialDataRead[Space+2]- 48) * 1;
break;
case 1:
tmp = 0;
tmp = (serialDataRead[Space+1]- 48);
break;
default:
break;
TxMsg4.Data8[0] = flag_negative;
if(flag_negative == 1)
tmp = -tmp ;
flag_negative = 0;
//TxMsg4.Data8[0] = flag_negative;
TxMsg4.Data8[1] = Digit;
TxMsg4.Data8[2] = Space;
flag_invalide = serialDataRead[0];
if ( (Space + Digit) != 10)
flag_invalide = 0x01;
if (Digit > 5 )
if ( flag_invalide == 0x20)
//TxMsg4.Data16[3] = tmp;
Space = 0;
Digit = 0;
for (i = 1 ;i <= 40; i++)
serialDataRead[i]= 0;
str_serial[i]= 0 ;
