LAN2CAN ROUTE DOESN'T WORK
CAN to LAN gateway in DIN rail plastic casing
quanhiahia
Post by quanhiahia » Tue 14. Nov 2017, 03:23
This is a student from Hanyang University in Korea. I purchased PCAN-Ethernet Gateway DR and I am trying to transmit CAN messages through LAN2CAN route for my project. I connected my PC1(192.168.0.1) to PCAN-Gateway(192.168.0.2) and I connected PCAN-Gateway to another computer PC2 through Vector. And I was hoping that I can receive CAN messages sent from PC1 in CANoe installed in PC2
I set up LAN2CAN route in the website interface, but it keeps showing there is problem, the light is always yellow,
And then I tried to send message in software SerialPortMon in PC1, but I can’t receive any message in CANoe in PC2.
I wonder whether the problem is my connecting way or I should change to use PCAN-View to transmit CAN messages. Furthermore, if I need to use PCAN-View, do I need to install Virtual PCAN-Gateway, too?
Thank you so much for your time and I would really appreciate it if you could reply to me at your earliest convenience.
Regards.
my connecting method
Re: LAN2CAN ROUTE DOESN'T WORK
Post by K.Wagner » Tue 14. Nov 2017, 09:00
Dear,
The routes are used to establish connection between Gateways and their CAN channels. The LAN communication is actually between Gateways, so you need at least two PCAN-Ethernet devices. Please check the help and these videos to obtain a better idea of what routes do.
If you only have one PCAN-Ethernet Gateway, then you need to use the Virtual Gateway (check the video) as second device. You can then use PCAN-View, PCAN-Explorer for receiving/sending data, or you can develop your own application by using PCAN-Basic or PCAN-Developer 4.
quanhiahia
Post by quanhiahia » Tue 14. Nov 2017, 13:33
Thank you so much for your help. It saves me a lot of time and really helps me a lot. I will try to connect with two gateways.
Yingshuai Quan
