Cannot upload/download program to lenze 9300 drive via CAN
USB to CAN Interface
stephan
Post by stephan » Thu 19. Apr 2018, 21:47
Hi, have an issue that i need some with
Have setup communication to the Lenze 9300 series drive via a diagnostic plug(the PC can cable is not connected directly to drive) and am using the GDC software
Had to select the drive manually from a list since the GDC software indicated it can not automatically detect the kind of drive. The drive then gets connected
Now when i try to save a parameter set from drive to PC i get a pop-up box 'save parameters to file'. when i click ok, nothing happens.
Re: Cannot upload/download program to lenze 9300 drive via C
Post by M.Maidhof » Fri 20. Apr 2018, 10:31
please contact Lenze support for help. GDC is not a software from PEAK, so we are not able to help you in that matter.
eizzuddin
Re: Cannot upload/download program to lenze 9300 drive via CAN
Post by eizzuddin » Wed 10. Jan 2024, 03:10
Hi Steven,
Are you able to solve it? may i have your email address? im facing same issue.
ieldlazy
Post by ieldlazy » Fri 12. Jan 2024, 11:40
Did you check file permissions? Ensure that the user account you are using to save the parameters has the necessary permissions to create files in the destination folder.
Post by PEAK-Support » Sat 13. Jan 2024, 17:06
as this is a LENZE application, please contact LENZE, search in a LENZE related Forum etc.
We will close this Thread now.
