[solved] Missing bus information in transmit list
rbmisc
Post by rbmisc » Wed 9. May 2012, 15:26
Each time I start PCAN - Explorer 5 I get messages in the Output window that my xmt messages are missing bus information in transmit list. I have gone to each xmt messages, selected edit message and then from the drop down list for Bus reselect the bus number. I press OK and the xmt indicates a change by *. I save this message, but this doesn't appear to fix the problem.
What am I doing wrong?
Re: Missing bus information in transmit list
Post by M.Maidhof » Thu 10. May 2012, 10:56
do you use several connections in your project? When you load a transmit list which does not contain a bus column, you will always be asked to select the bus for those messages. When you save the transmit list with this information, PCAN-Explorer 5 will never ask again.
Which version of PCAN-Explorer do you use at the moment?
rbmisc
Post by rbmisc » Mon 14. May 2012, 20:47
I only have 1 bus and I have saved the transmit messages several times but the bus assignment is not being saved with the message. Version 5.1.1.658
Post by M.Maidhof » Tue 15. May 2012, 09:37
as a first step, please update to the latest version 5.2.2, see news feed in your PCAN-Explorer startpage for downloadlink to the latest setup.
rbmisc
Post by rbmisc » Thu 17. May 2012, 18:35
I have updated to the latest and the first time opening it, I get the same message. So I tried editing 2 of the transmit messages and saved them. Closed the program and restarted. It is still doing the same thing.
Post by G.Lang » Fri 18. May 2012, 09:55
unfortunately we are not able to reproduce your problem. Please send your complete project and the XMT-file to support@peak-system.com. Which build-version of the PCAN-Explorer do you use?
Post by G.Lang » Fri 25. May 2012, 11:44
The problem is fixed and solved with the next release (> 5.2.2)
(thanks again to rbmisc)
