I am trying to install the driver of the Peak PCAN USB for my Beagle Bone Black. I am running ubuntu 14.04 on the beagle bone black with kernel version 3.8.13.bone59.. here is the wiki
http://elinux.org/Beagleboard:Ubuntu_On ... Bone_Black
Thanks to Michael for referring me this post
http://www.peak-system.com/forum/viewto ... f=59&t=256
it helped a lot in installing the driver on my Ubuntu virtual machine and it is working. I mean the driver is successfully installed and I can see it is connected.
Now by using the same procedure I am trying to install the driver for my beagle bone. Initially it was giving me error that version.h file is missing. I found a post here
http://www.peak-system.com/forum/viewto ... bian#p1934
and I have updated the source file headers of beagle bone black. I have used these instruction from the developer may be useful for someone else
https://groups.google.com/forum/#!topic ... 5RLNUGYrAc
Now after updating the kernel header the version.h problem was solved. I again tried to follow the steps mentioned in the previous post for installing drivers for ubuntu but still not successful, see below for the response,
1) make clean
respone:
So far its fine no version.h file problem as before,ubuntu@arm:~$ uname -r
3.8.13-bone59
ubuntu@arm:~$ cd peak-linux-driver-7.13
ubuntu@arm:~/peak-linux-driver-7.13$ make clean
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/driver'
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/driver'
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/lib'
rm -f src/*~ src/*.o *~ *.so.*
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/lib'
make[1]: Entering directory `/home/ubuntu/peak-linux-driver-7.13/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcan-settings
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/test
2) make NET=NO
response:
Now if I compare this with my Ubuntu virtual machine when I was installing, the response is not the same because I am having some errors hence can't create the .ko file for the driver and installer is giving an error that .ko file is missing.ubuntu@arm:~/peak-linux-driver-7.13$ make NET=NO
make[1]: *** No rule to make target `depend'. Stop.
*** Host machine kernel version=3.8.13-bone59
*** Driver kernel version=3.8.13
*** Path to kernel sources=/lib/modules/3.8.13-bone59/build
*** use KBUILD=yes
make -C /lib/modules/3.8.13-bone59/build SUBDIRS=/home/ubuntu/peak-linux-driver-7.13/driver EXTRA_CFLAGS="-I/home/ubuntu/peak-linux-driver-7.13/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-3.8.13-bone59'
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_main.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_fops.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_fifo.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_filter.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_parse.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_sja1000.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_common.o
CC [M] /home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.o
/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.c: In function ‘pcan_pci_probe’:
/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.c:610:2: error: implicit declaration of function ‘pcim_enable_device’ [-Werror=implicit-function-declaration]
err = pcim_enable_device(pciDev);
cc1: some warnings being treated as errors
make[3]: *** [/home/ubuntu/peak-linux-driver-7.13/driver/src/pcan_pci.o] Error 1
make[2]: *** [_module_/home/ubuntu/peak-linux-driver-7.13/driver] Error 2
make[2]: Leaving directory `/usr/src/linux-3.8.13-bone59'
make[1]: *** [all] Error 2
# ln -sf ../driver/pcan.h pcan.h
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings -lpopt -g
make[1]: Leaving directory `/home/ubuntu/peak-linux-driver-7.13/test'
I am not sure what to do about it now, any help in this regard will be highly appreciated. Please let me know if more information is required.
Naqqash
