Power routed to Pin 2 of M12 CAN connectors
6-Channel CAN FD Interface for High-Speed USB 2.0
dfcossio
Post by dfcossio » Wed 6. Dec 2017, 17:49
I was wondering if it is possible to route the voltage of the external power supply to the pin 2 of the CAN M12 connectors on the PCAN-USB X6 so I can provide power to my CAN sensors using the same cable.
I've attached the pin out of my CAN sensor
CAN sensor pin out.JPG (18.54 KiB) Viewed 5229 times
Thanks in advance!
Diego
Re: Power routed to Pin 2 of M12 CAN connectors
Post by PEAK-Support » Thu 7. Dec 2017, 09:19
Sorry, this is NOT possible ! The GND (U- Pin 3) could not be used, because this is the isolated GND of the CAN Transceiver and it is NOT connected to the Supply GND !
