No UDP Traffic
Archigos
No UDP Traffic
Post by Archigos » Wed 28. Mar 2018, 01:23
I've got a benchtop test setup with two PCAN Ethernet Gateways connected via a ethernet hub to pass CAN data in a unidirectional setup. The units show green lights indicating a good connection but I don't see any UDP traffic on the network and thus no output CAN data. The CAN Bus traffic that I want to forward uses extended message ID's but even when I just sent a single cyclic message with a 11bit ID I was still not seeing any forwarded traffic. Hoping someone can clue me in on why I don't appear to be seeing any data being forwarded?
Sending Unit Status
Sending Status
Sending Status
Receiving Unit Status
Receiving Status
Receiving Status
Re: No UDP Traffic
Post by G.Lang » Wed 28. Mar 2018, 10:18
Hello Archigos,
please update to firmware 2.6 and disable the "Listen-Only" mode at the sending unit.
Archigos
Re: No UDP Traffic
Post by Archigos » Wed 28. Mar 2018, 18:27
Worked like a charm.
