Unable to see msgs being received: 2 interfaces back to back
USB to CAN Interface
KenMacfarlane
Post by KenMacfarlane » Fri 31. Aug 2018, 10:56
Hi - I'm having basically the same problem as was described here:
https://www.peak-system.com/forum/viewt ... f=7&t=2348
i.e. 2 brand new interfaces, cabled together using pins 2,3 & 7, with 4 270 Ohm resistors in parallel slugged across CAN high & low in the middle of 10cm long piece of untwisted ribbon cable to allow me to use 9 pins IDC connectors, crimped onto the cable. The cable is short enough that I wouldn't have thought that I need to terminate it at each end.
I'm running 2 instances of PCAN view & I've set the ID's to something other than the default FF for each interface. I can transmit (i.e .the transmit counter is incrementing each time that I hit the space bar), but nothing appears in the received window at the other end. I don't have a scope handy never mind differential probe - I haven't checked whats on the bus yet. The Red leds are on solidly, and I did install the drivers off the CD before inserting the USB plugs into my laptop. I'm not using any cable extensions or going through an unpowered hub.
PCANview seems intent on showing me 2 copies of the same interface, so perhaps I just need to figure out how to tell the 2 apart?
PCAN view Interface state.png (116.24 KiB) Viewed 8792 times
Re: Unable to see msgs being received: 2 interfaces back to
Post by M.Maidhof » Fri 31. Aug 2018, 11:06
the PCAN-View in the picture shows "not connected" in the status bar. Please select a real CAN channel to be able to transmit and receive CAN messages with the hardware.
KenMacfarlane
Post by KenMacfarlane » Fri 31. Aug 2018, 11:22
#1: Opened one PCAN view for device FD.
#2: Despite trying picking device FE, another PCAN view is opened for FD, so when I try to connect on #1, I get this error.
What am I doing wrong? The PCAN-USB tab seems to let me change the device ID on the hardware, but not change which device the instance of PCAN view is attached to.
Post by M.Maidhof » Fri 31. Aug 2018, 13:43
please goto the menu of PCAN-View and select CAN->Connect, to connect the different PCAN-View instances with different hardware channels.
If the problem still exists, please contact us by email to arrange a teamviewer session on your system.
KenMacfarlane
Post by KenMacfarlane » Fri 31. Aug 2018, 16:41
I tried that already and couldn't get PCAN view to use the other interface even though I selected it. So I'll email you with a view to sharing my desktop on Monday morning (I'm on a train just now so I can't plug the hardware in).
Post by PEAK-Support » Mon 3. Sep 2018, 08:23
Problem should be solved - we send to the customer a step by step tutorial
So it should work now - no feedback until now...
but no feed back in the world of supporters means "it is working.." :roll:
KenMacfarlane
Post by KenMacfarlane » Mon 3. Sep 2018, 11:39
The problem still exists - I read that instructions but I still couldn't see how to set the 2 instances to different hardware addresses - when I select the 2nd devices address, it just reverts to the first one.
I'm just getting my desk setup for remote working - will be in touch shortly. Can you please email me a phone number or Skype ID, or instructions for how you want to see my desktop?
Post by M.Maidhof » Mon 3. Sep 2018, 12:18
please contact us through our support email address or contact us by phone to arrange a teamviewer session.
+49 6151 817330
