Problems about PassThru Connecting to CAN
jworker
Post by jworker » Mon 10. Dec 2018, 06:29
Dear Managers:
I'm sorry to have taken up your valuable time.
I have some problems when I calling the PassThruAPI -> PassThruConnect, It never works properly. The function takes five parameters, it is not only different with SAE J2534_1_201510 but also SAE J2534_200202. I don't have a clue that this function is implemented from which standard.
and does PEAK provide interfaces that implement J2534_1_201510 standards or some other exact version PassThruAPI.
My office computer is Windows7 64-bit, and I am using 32-bit DLLs.
Thank you, with my best regards.
Re: Problems about PassThru Connecting to CAN
Post by K.Wagner » Mon 10. Dec 2018, 09:34
PLEASE NOTE: Don't post question twice! This will not speed up an answer.
The current version of PassThru is using the standard revision from 2004.
PassThru Standard
PassThru Standard
IN this version, PassThruConnect use 5 parameters:
Parameters
Parameters
jworker wrote:does PEAK provide interfaces that implement J2534_1_201510 standards or some other exact version PassThruAPI.
Our devices support CAN and CAN-FD. The support for high layer protocols is done over APIs. The PassThru API offered by PEAK is following the specifications of the SAE document J2534_1_2004-xx.pdf
