An instrument panel Actor feedback signal will not result in a tx message if it is defined in the J1939 proprietary spaces.
One can define and place a signal into J1939 Proprietary ID spaces (PropB_00-FF, PropB1_00-FF, PropA/A1). If using an Instrument Panel object, e.g. an analog slider, one can associate the signal as expected in the object config panel but a feedback transmit message will not be generated within the PE6 transmit window. Simply dragging the signal to another message data byte, for example (PropB_00 ID - 1) and the feedback feature works. I've been unable to find any rules for this feature in the reference materials or help files.
PE6 Instrument Panel Object Actor limitation?
Re: PE6 Instrument Panel Object Actor limitation?
I was unable to replicate this issue,
can you provide us more information to further assess the issue?
Which Version of PCAN-Explorer 6 are you running ? (See: Help -> About PCAN-Explorer).
I assume you customized a copy of the J1939-Template Symbol-File?
Can you provide a screenshot of how your symbol (PropB_00 for example) is set up, when this
behaviour occurs?
behaviour occurs?
resolved. On stepping through it again, I did not reassign the symbol to the instrument object after changing the database.
Thank you for letting us know what the cause for this was.
For further questions do not hesitate to contact us again.
