Forward all messages from CAN's with different bit rates
Designwerk
Post by Designwerk » Wed 7. Apr 2021, 11:35
Hi!
We plan to get a PCAN-Router Pro for the following application.
Is it possible to forward all messages from one CAN with 667 kbit/s to another CAN with 1 Mbit/s and a few messages in the other direction?
Thank you,
Joel
Re: Forward all messages from CAN's with different bit rates
Post by PEAK-Support » Wed 7. Apr 2021, 12:42
Yes, that i spossible. If you only have 2 seperate CAN Neztworks, the smaller PCAN Router or PCAN-Router FD could also be used.
Designwerk
Post by Designwerk » Mon 3. May 2021, 16:37
Thanks, but how do I set this special bitrate of 667kbit/s?
Post by M.Heidemann » Tue 4. May 2021, 08:26
The a custom bitrate can be defined in Firmware
on both devices. The approach varies slightly due to
different controllers being used, but the examples
provided give a good idea on how one would
implement his custom bitrate into his application.
We offer a bitrate calculation tool which helps to
find the correct bitrate timing settings for your custom
bitrate:
https://www.peak-system.com/fileadmin/m ... onTool.zip
A more specific sample can be given, if you tell us which device you want to use ultimately.
Designwerk
Post by Designwerk » Tue 4. May 2021, 08:59
Thanks for the Tool, this gives a good idea how it's done.
We will use the PCAN-Router Pro because we need all the four channels.
Best regards
Joel
Post by M.Heidemann » Tue 4. May 2021, 11:31
Thank you for your feedback.
If you use the PPCAN-Editor for your configuration, you will have to use the I/O function "CANx Bitrate Raw" to
set a custom bitrate, not included in the bitrate dropdown (set the "user"-bitrate here, in this example bitrate = 666,667 kbits):
2021-05-04 11_27_16-Window.png (14.14 KiB) Viewed 6749 times
See page 64 of the PCAN-Router Pro User manual regarding this:
Designwerk
Post by Designwerk » Tue 4. May 2021, 13:23
Thanks a lot. It works.
Best regards
Joel
