MIO Pull-up / Pull Down
Clemlsn
Post by Clemlsn » Fri 10. Jun 2022, 11:25
I just received a Pcan MIO industrial version.
I want to use the Din of the MIO to observe the state of some outputs from my board.
I created the message in PPCAN:
Then I linked the message to the Din pins:
I loaded the configuration in the MIO.
So I have the correct message sent at the correct rate, but it seems that there a default pull-up in the system that puts the measurements at 8.5V.
I need to use a pull down for my set up, but it seems that the configuration is not available in PPCAN editor:
In the user manual, I'm suppose to have the function 88h to modify the pull-up pull-down for the digital inputs:
How can I solve this ?
I'm using PPCAN editor version 2.2.2.260
S.Schott
Hardware Development
Re: MIO Pull-up / Pull Down
Post by S.Schott » Fri 10. Jun 2022, 15:41
Hello there.
When creating this config, you have probably chosen MIO instead of MIO32.
With MIO32, you may configure the pull resistors as expected (see screenshot).
Greetings,
Stefan
Clemlsn
Post by Clemlsn » Fri 10. Jun 2022, 16:02
indeed that was it. Thanks for the support !
Clément
