I have configured my PCAN Ethernet Gateway and Virtual PCAN Gateway for using both CAN channels. Therefore I added 4 routes (see attachments for more information). No matter what I do, there is only one CAN channel available in PCAN View. I have tried all sorts of combinations (TCP, UDP, different ports, ...). All 4 routes are "green" in the vitual PCAN-Gateway Configuration Tool and in the Web Gui of the Gateway.
Can anybody give me a hint what could be wrong here?
BR
Sebastian
Only one CAN Channel on Virtual PCAN-Gateway
- only one channel available instead of two
- pcan_view.PNG (41.06 KiB) Viewed 3676 times
RoutesConfiguration.vpoi.txt
- (3.54 KiB) Downloaded 2034 times
poi_config.ini
- (5.24 KiB) Downloaded 2173 times
Re: Only one CAN Channel on Virtual PCAN-Gateway
We need additional infos, for doing this please download the SysInfo tool from the following URL:
https://www.peak-system.com/fileadmin/m ... ysInfo.zip
Usage: unpack the ZIP and start the *.EXE (no installation required), let the analysis run and avoid the "Quick-Scan" option, save the result as a XML file and send the XML file to "support@peak-system.com"
