EWMA function on PCAN-Router Pro
ishara
Post by ishara » Wed 27. Sep 2023, 05:34
I'm wondering, is there any possibility to program EWMA filter in PCAN-Router Pro? Basically I have a 12bit signal which I want to smoothen using EWMA filter and introduce back to CAN bus. I did this with PCAN router FD but, not sure how to do this in PCAN-Router Pro.
PCAN-Router Pro has a low-pass filter but, I want to go beyond 1st order smoothning.
Re: EWMA function on PCAN-Router Pro
Post by M.Maidhof » Wed 27. Sep 2023, 10:03
the PCAN-Router Pro can also be used/flashed with an own application/firmware. You don't need to use the standard firmware for this. Simply build a firmware for PCAN-Router Pro with your EMWA filter using our PEAK-Dev package, as you have done with PCAN-Router FD. Please use one of the examples for PCAN-Router Pro as a template.
ishara
Post by ishara » Wed 27. Sep 2023, 14:09
Thanks a lot.
I cannot locate "Yagarto GNU ARM toolchain for Windows" in your website. Can you please help me to locate? Also, any tutorial guide to use it?
Thanks Again
Post by PEAK-Support » Wed 27. Sep 2023, 17:17
The "Yagarto GNU ARM toolchain for Windows" is outdates since some years.
Please download the ARM-Developer Package - this is one package for all µC based unites with ARM cores - also PCAN-Router PRO. (see product description / download section of product)
