Internal clock tolerance
dlslb
Post by dlslb » Fri 16. May 2025, 15:48
What is the tolerance and temperature coefficient of the internal clock of the PCAN-USB FD?
My bus has 200ppm oscillators at all nodes. It would be great if the PCAN-USB was as accurate.
Re: Internal clock tolerance
Post by M.Maidhof » Mon 19. May 2025, 13:11
please provide the serial number (IPEH-XXXXXX yyyyyy) of the used PCAN-USB FD device, to see which hardware revision you are using.
G.Bohlen
Hardware Development
Post by G.Bohlen » Tue 20. May 2025, 15:39
clock is based on a crystal with a frequency tolerance of 30ppm and a frequency stability of 30ppm within temperature of -40°C to +85°C. Thererfor the input clock can vary by 60ppm. The CAN output clock is created by using several digital dividers that do not change the accuracy.
Gunnar Bohlen
